08 DOUBLECAB LIFT BUILD
Discussion in '2nd Gen. Builds (2005-2015)' started by brandon1647, Aug 5, 2013.
  1. Aug 5, 2013 at 7:34 AM
    brandon1647
    brandon1647 [OP] Well-Known Member
    Brandon
    Orlando, FL
    08Prerunner SR5 TRDoffroad doublecab
    Leather seats, JVC head unit, ORION Clarion 15" sub woofer, Halo Projector LED headlights, plastidipped console, grille, and emblems, LED map & dome lights, matte black TRD decals
    2008 double cab prerunner
    I Bought the truck from STINGRAY Chevrolet in Tampa, Fl with 45,00 miles. Everything was stock, except the seats, The one previous owner before me owned an upholstery shop and put in leather seats.
    Front lift
    - Bilstein 5100 adj shocks. set at 1.75"
    - Eibach coils 1.6"
    - Maxtrac 4" spindle
    Rear lift
    - Bilstein shocks 3-4" lift
    - 4" block
    Mods
    - Satoshi grill with landcrusier emblem
    - Halo headlights
    - Matte black bedside decals
    - White LED interior lights
    - LED shifter light
    - Plasti-dipped emblems
    - 15" ORION Sub
    - JVC headunit
    - Carrier bearing drop bracket
    Still might be forgetting a few
    I drove it how it was for about two years, then decided to start modding it.
    put in a JVC KD-PDR80 head unit ( free ).
    Then ORION Cobalt 15" sub.
    - painted my dash kit around my head unit, and shifter console.
    Halo projector headlights ( eBay lights)
    The chrome grille kind of looked weird now with black headlights, so I decided to plastidip it.
    did the emblems all the way around
    Ordered a Matte, and gloss black sticker from TipTopsigns
    White LED map & dome lights
    Finally started buying parts for the lift .
    Maxtrac 4" spindle and Eibach coils
    -Bilstein 5100's adj shocks.
    - 4" block and another set of billys for the back
    Didn't really feel like disassembling my stock strut to use the top strut spacer on my new set up
    Finally ready to start lifting it.
    Didn't have my tires and rims yet, and my stock rims wouldn't fit because the offset, and it hit my new spindle. so I had to borrow and chevy rim from my buddy and my spare tire flipped backwards. I just put them on so I could put the rear lift on.
    Picked up the tires and rims from discount tire today
    295/70/18 Nitto Trail Grappler M/T
    18" XD addict
    ( 34.2" tall & 11.6" wide )
    ( 4.5" backspace )
    THANKS FOR LOOKING!
    Let me know what you think
    Will be adding to the thread as the build progresses!
  2. Aug 5, 2013 at 9:51 AM
    Surfside77
    Surfside77 Well-Known Member
    Columbia South Carolina
    2012 TRD Sport V6
    TRD Exhaust, Bull Bar, Leather
    Lookin Good!
  3. Aug 5, 2013 at 11:49 AM
    brandon1647
    Brandon
    Orlando, FL
    Thanks man
  4. Aug 6, 2013 at 7:08 AM
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    dang. looks so badass
  5. Aug 6, 2013 at 1:31 PM
    BLOODYMARY
    BLOODYMARY Well-Known Member
    Keith
    Tulsa, OK
    2012 Tacoma Double
    AFE Exhaust, AFE Panel Filter
    Looks great!!
  6. Aug 7, 2013 at 7:51 PM
    brandon1647
    Brandon
    Orlando, FL
    Bought a little Smith & Wesson off ebay for $8. Mounted it on the bottom of my little tray compartment by my ignition.
    wanted to take it through a few trails to see how the tires hooked up.. ( first time using GoPro )
  7. Aug 23, 2013 at 7:03 AM
    brandon1647
    Brandon
    Orlando, FL
    Finally finished my satoshi. Will post write up and pictures later!
  8. Aug 29, 2013 at 8:42 AM
    brandon1647
    Brandon
    Orlando, FL
    Got around to doing the satoshi grill mod. Took two days, just had to drive it one day with bondo all over it. Definitely recommend having another grill to do the work on.
    Used the Fiberglass repair kit from autozone
    - Perforated aluminum SS from CUSTOMCARGRILLS
    I cut the heads off of screws, and used plastic epoxy to hold them against the plastic. I had to drill tiny holes for the screws to fit through, then just put the washer and nut on it.
    - For the triangle cut outs, I just screwed it into the back of the plastic to keep it flush
    - cut out the front bumper plastic and did the same thing to the bottom
    - Sanded the grill with 80 grit, 150, then 220. Sprayed adhesion promoter, Black sandable primer, the Duplicolor color match flat black.
  9. Sep 1, 2013 at 1:12 PM
    Liam TRD
    Liam TRD Active Member
    Liam
    upstate, sc
    06 TRD off road 4x4
    Work in progress
    looks good! Im jealous of the leather
  10. Sep 1, 2013 at 1:41 PM
    brandon1647
    Brandon
    Orlando, FL
    Thanks man!
  11. Sep 1, 2013 at 1:48 PM
    brandon1647
    Brandon
    Orlando, FL
    FINALLY got the carrier bearing drop bracket. Had some vibration from in between 5-15 mph. Dropped it 1 3/4" and it rides smooth now
  12. Sep 2, 2013 at 12:07 PM
    jayhud11
    jayhud11 Well-Known Member
    jason
    valdosta, ga.
    08 4x4 double cab
    How do you like your headlights? Thinking about getting some.
  13. Sep 2, 2013 at 12:21 PM
    brandon1647
    Brandon
    Orlando, FL
    They're awesome. Although I had to do some playing around with the wiring. The LED strip doesnt run all the way to the top, So i tied them into my parking light wire, to bring them to the top of the light.
  14. Sep 24, 2013 at 8:00 AM
    brandon1647
    Brandon
    Orlando, FL
    Been a while since I've been on, figured I'd add a picture from work..
  15. Sep 24, 2013 at 4:31 PM
    looneytunemagoun
    looneytunemagoun Well-Known Member
    james
    Leicester,mass
    SR5
    Truck looks great
  16. Sep 25, 2013 at 8:31 AM
    brandon1647
    Brandon
    Orlando, FL
    Thanks man!
  17. Oct 28, 2013 at 12:56 PM
    mason
    mason Well-Known Member
    mason
    Georgia
    05' white tacoma
    k&n cold air intake system, westin bull guard w/ off road lights, 20% tinted windows, 3 inch suspention lift, uws low profile tool box, 18" fuel krank rims w/ 33" nitto mud grapplers halo headlights, led taillights memphis door speakers w/ a 1400 touch pioneer head unit, 2 10" JL w1 subwoofers with 500/1 JL amplifier, weathertech floor mats, led bed lights, led dome/ map light/ 10000k hid low and fog lights, fog light anytime mod, custom fuel offroad grille, dual flowmaster 40 exhaust system,
    I am in love with your truck haha how much did you spend on your lift
  18. Oct 29, 2013 at 7:17 AM
    brandon1647
    Brandon
    Orlando, FL
    Thanks lol! I spent $1,040 for the complete set up. I didn't buy it all as one though. I bought a few parts at a time and got a few deals.
  19. Oct 29, 2013 at 7:56 AM
    brandon1647
    Brandon
    Orlando, FL
  20. Oct 30, 2013 at 8:53 PM
    mason
    mason
    Georgia
    05' white tacoma
    you put it on yourself righta?
