08 factory installed alarm (need help)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hardtaco, Dec 19, 2010.
  1. Dec 19, 2010 at 10:26 AM
    hardtaco
    hardtaco [OP] Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    Anybody have any operating instructions on the 08 factory / dealer installed alarm system? I bought an 08 that has it, and I have no paperwork on it's operations, settings, ect. It is the one that has the red led that is actually a button that can be depressed, mounted on the dash low under steering column.
  2. Apr 9, 2011 at 8:25 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    Bump
    I have the exact same question.
  3. Apr 10, 2011 at 8:03 AM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    What problems are you having? I just got done messing with mine and determined it was in Valet Mode. Looked under dash and determined dealer had installed an Audiovox Pursuit, however the Valet Mode instructions weren't applying. Scoured through paperwork that came with truck and learned I needed to cycle power on key 3 times to make switch active.
    RZ Rob
