08 lift with Bilstien question
Discussion in 'Suspension' started by kansay, Mar 25, 2011.
  1. Mar 25, 2011 at 6:17 PM
    kansay
    kansay [OP] Well-Known Member
    dude
    Twin Cities, MN
    08 tacoma dbl cab 4x4 sport
    Bilstein shocks front and back.
    I've installed my bilstien shocks on all 4's with TSB done and now I'm getting this wobble on my truck. Is anyone having the same issue?
    The shocks are better than the stock oem shock for ride comfort but can feel the roads more than before. Seems like I can feel every bumps and cracks on the roads. Also when I hit a bump or cracks the car seems to drift and sway. I've took it to Toyota and they did point out that the car does sway and wobble and says that something seems bent in my suspension. Anything can help to resolve this issue.
  2. Mar 25, 2011 at 6:23 PM
    kansay
    dude
    Twin Cities, MN
    yes I did at 2 different places.
  3. Mar 25, 2011 at 6:59 PM
    kansay
    dude
    Twin Cities, MN
    Would changing my spring make a difference in the situation? and also with a heavy load the car drives fine.
  4. Apr 1, 2011 at 12:58 PM
    kansay
    dude
    Twin Cities, MN
    Well I guess I'm going for some new springs, any idea on the best one to get? I got the front on .85 on the bilstiens and would like to keep it that way, any suggestion would be appreciated.
  5. Apr 1, 2011 at 1:04 PM
    kansay
    dude
    Twin Cities, MN
    Toytec/Eibach front coil springs or OME front coils spring?
    Don't want a 2 inch lift just 1 inch or so.
    thanks
  6. Apr 1, 2011 at 1:13 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The smallest lift springs I know of are the eibachs, 1.6".
  7. Apr 1, 2011 at 6:00 PM
    kansay
    dude
    Twin Cities, MN
    Do you think that this will fix my issue I have now with the wobbling of the truck at high speed?
  8. Apr 2, 2011 at 7:15 AM
    KPT
    09 Prerunner
    I do not. I think it is more than likely that some portion of the suspension is damaged, as the tech suggested, or that something is not torqued down correctly.
  9. Apr 2, 2011 at 7:17 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i would agree that sometihng is messed up under there. check all bolts, nuts, check the sway bar and control arms
