08 poor gas milage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rpoint16, Sep 11, 2007.
  1. Sep 21, 2007 at 8:58 AM
    106Tacoma
    106Tacoma Well-Known Member
    Debadged 06 Black Sand Pearl 4x4 Every option.
    No my truck has a 14 gallon tank. I ran out of gas once when i first got it 13.5 gallons filled it up.
  2. Sep 21, 2007 at 9:12 AM
    Rich Swanner
    Rich Swanner Well-Known Member
    N.California
    2007 Black PreRunner DC V6 SR5 LB
    Leer 100R Shell NXT Tech Wax
    You need to go back to where you bought it because everyone else has a 21 gallom tank and they will GIVE you one because that is what you SHOULD have. They OWE you a correct size... Have them add the extra spring and tailgate too(TSB ) ..tell them even with the small tank you are bottoming out and have a rough ride...Good Luck...Rich [​IMG]
  3. Sep 21, 2007 at 9:54 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Are you in Canada? Are we talking about imperial gallons?
  4. Sep 21, 2007 at 11:13 AM
    WildcaTaco
    WildcaTaco Well-Known Member
    06 Access Cab V6 TRD Off-Road PreRunner
    Removed Secondary Air Filter
    yeah Tacoma's do not come stock with a 14 US gal tank. Not sure about the imperial gallon thing b/c according to my calculations 21 US gallons roughly equals 17.5 Imperial gallons.
  5. Sep 21, 2007 at 11:34 AM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    I am just trying to figure out what is going on. :confused:
  6. Sep 24, 2007 at 8:11 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    yeah, there is no way he should have a 14 gallon tank, even if it is imperial gallons thats too small. You DEFINATELY need to confirm your tank size and if its not 21 gallons, then you need to take it up to the dealer and raise hell
  7. Sep 25, 2007 at 7:46 PM
    Rich Swanner
    N.California
    Coming up on 1k will post...Rich
  8. Oct 7, 2007 at 8:32 PM
    derk
    derk Member
    I have a 2006 Access cab with the V6 and the best mileage I've gotten over a period of 20k is 24mpg. I can get this by keeping my rpm's less then 2000 as much as possible. Recently I hooked up a 3000 pound travel trailer and was able to still do 20mpg, this however will vary depending on headwind, hills etc. and has been as low as 10mpg. Overall i'm happy having driven a 1992 Ford F250 with a 5.0 302 engine, without a tow vehicle I used to get at best 15mpg, then with a 6000 pound trailer it used to drop to 8-10mpg. I added a Undercover bed cover which I could not be more happy with, no difference in mpg after 10k with the cover. It does make for a secure trunk area. Biggest tip I can suggest is to watch your RPM and keep them below 2000. My truck is an AUTO trans by the way.
    As long as I don't go over 2000 RPM my mileage is always above 22mpg. This does not seem to be a problem even going up hills. My suggestion is if you want to raise your MPG stay under 2000.
  9. Oct 7, 2007 at 9:04 PM
    Rich Swanner
    N.California
    I got 21.47 MPG with my new Leer 100R shell on highway/city. I am at 1,400 on the odometer.-Rich IMG_7608_edited-1Large1_edited-2_6a3fdb281b9971ae68a16719ae02d85303706644.jpg
  10. Oct 7, 2007 at 9:42 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Same for me, at about 5-6k gas mileage improved.
  11. Oct 12, 2007 at 6:07 PM
    Bubba-Jet
    Bubba-Jet Active Member
    Wyano PA.
    07 Tacoma SR5 TRD 4X4 Sport
    Removed Secondary Air Filter,Tacomaworld Sticker,Wade In-Channel wind deflectors,Fumoto 12mm.F103N Engine Oil Drain Valve,Home Cast Bed Tie-downs
    My Tacoma is 2 weeks old and already have 2000 miles on it .I do see a increase in mileage. Good thing first tank 12, second 14 , third 12.5 , Fourth 14 ,Fifth 16,Sixth 18.I still need to remove the charcoal in the Airbox
  12. Oct 13, 2007 at 4:21 AM
    ellsworth
    ellsworth Well-Known Member
    Buffalo
    08' off rd 6 speed
    6 inch Fabtech, st stabilizers, 18x9 DC -1s 305/65/18 bfg at's
    being a truck person since getting a licence I am alway amused at the fuel economy question..Prior to the 08 #s on the window sticker, on any vehicle one might look at, I recomend looking at the very small reported to #s that your eyes are not drawn to due to the very large lab test #s...I guess after driving big 3 half tons for almost 20 years the tacoma gets excelent millege to me...The power to weight ratio is always impresive each time I drive..4.10 and a six speed its a hot rod with a big trunk...
  13. Oct 13, 2007 at 8:03 AM
    sandie
    sandie Well-Known Member
    long beach, ca
    06 x-runner baby!
    looks like the V6's vary widely...my 06 consistently gets 17 around town (30k on the ODO)...i keep waiting for it to get better :sad: i keep the RPMs at 2500 typically...maybe that's the problem? seems sluggish to me under 2k
  14. Oct 13, 2007 at 8:15 AM
    SilverStreaker
    SilverStreaker Member
    Rochester, NY
    2008 DC 4x4 TRD Sport
    I have a 2008 as well and I just recorded 20.3 mpg which includes highway and city commuting. Pretty damn good if you ask me.
  15. Oct 13, 2007 at 6:04 PM
    #35
    Saguaro
    Saguaro Member
    Rancho Palos Verdes, CA
    07 V6 6-spd 4WD Access Cab, TRD Off-Road Package, Super White, Suspension TSB
    I have a 2007 V-6 6-spd 4x4 access cab with about 850 miles. My first 2 tankfulls only gave me about 15 mpg combined. My third tankfull gave me 16mpg. I'm on my fourth tank now. Hopefully it is starting to go up.
  16. Oct 14, 2007 at 2:37 PM
    #36
    supra90140
    supra90140 Well-Known Member
    telford pa
    08 dbl cab 4x4 lb trd sport speedway blue tow pkg
    weather tech floor liners
    i just got my 08 dblcab lb sport tacoma last month and the first tank i got 16 but i was driving in 4 the whole time. second tank got better around 18 and the next six were 9 but i was towing up hills alot. the manual says to not tow before 500 miles and to try not to rev it at high rpms and vary your speed i think. I did get 19 but seem to ave around 18. thats non highway. havent did much of that yet to check it. by the way these trucks tow great. 3 quads, 1000lb trailer, 3 guys and all our gear to west virginia from pa did great. only 9mpg but there were alot of long hills. but it still could go 90 up any of em. love this truck so far.
  17. Oct 15, 2007 at 10:05 AM
    #37
    nd
    Nate
    Greenville, SC
    why were you in 4 for the first tank? thats alot of off-roading/bad weather
  18. Oct 15, 2007 at 10:56 AM
    #38
    supra90140
    telford pa
    not 4x4 .. Im retarded and for some reason thought the 4 and the D were together cause im used to 4 being the highest gear for an automatic and just assumed when it said it had 5 gears they were just inclucing reverse.
  19. Oct 15, 2007 at 1:13 PM
    #39
    nd
    Nate
    Greenville, SC
    Oh i gotcha.
  20. Oct 15, 2007 at 1:29 PM
    #40
    kristopherl
    kristopherl AKA: Jake the Wolf
    Cincinnati, Ohio
    08 Tacoma DC 4x4 Sport LB. Foglight
    Cup holder LEDs, Black Max Tonau, BHL Mod, N-Fab side steps
