08 taco spark plug upgrade ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LEEP, Mar 18, 2009.
  1. Mar 18, 2009 at 7:25 AM
    LEEP
    LEEP [OP] Well-Known Member
    LEE
    CONNECTICUT
    O8 TACOMA TRD
    What are the best plugs 2 use replaceing originals with long life dont want 2 chng them every 30 thou
  2. Mar 18, 2009 at 7:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    From what I have found in my research, if you switch to iridium or platinum plugs, you get less performance from the engine. IMHO, use what the manual suggests, and just change them when required. :)
  3. Mar 18, 2009 at 1:24 PM
    isusww
    isusww Well-Known Member
    I agree. I changed mine to NGK Iridiums all around and have seen a noticable difference in gas mileage. When I change them again, I'm putting in recommended plugs!
  4. Mar 18, 2009 at 1:36 PM
    BIGLuke
    BIGLuke I'm a TW addict!
    Luke
    Chicago suburbs IL
    07 4X4 tacoma SR5 Double Cab Shortbed Speedwy
    Did your gas milage go down or up when you changed to NGK? I have the same ones and i havent really noticed any difference.
  5. Mar 19, 2009 at 3:40 AM
    LEEP
    LEE
    CONNECTICUT
    O8 TACOMA TRD
    lets hear more input
  6. Mar 19, 2009 at 4:19 AM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    With the write up that chris did here and the $25-$30 it would cost for denso coppers ever couple of years, just stick to the OEM.
