08 tacoma 4.0
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joe toy, Nov 5, 2020.
  1. Nov 5, 2020 at 10:24 AM
    joe toy
    joe toy [OP] New Member
    2008 toyota tacoma trd sports
    stock
    I got 2 lean codes po171, and po174 hesitates like running out of fuel at 2000 rpms and up. has new fuel pump 55lbs at ideal 65lbs when stab it. new mass air flow senson, new fuel regulator, new o2 sensor, new intake gaskets, and long term fuel is at 39% looking for some info on what could be going on with it. only has 13,000 original miles.
  2. Nov 5, 2020 at 10:25 AM
    Bishop84
    Bishop84 Well-Known Member
    Fuel pump. It's starving for fuel on both banks.
    There's no fuel pump code so it has only lean codes to trigger. Good luck!
    TnShooter likes this.
  3. Nov 5, 2020 at 10:33 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    I've seen those codes pop up with exhaust leaks. Any strange exhaust sounds, maybe go under with a bottle of soapy water and spray on flanges when truck is running.
    BassAckwards and TnShooter like this.
  4. Nov 5, 2020 at 1:19 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Fuel pressure is supposed to be 43.5psi normally.. are you getting the pressure reading at the fuel rail?
  5. Nov 5, 2020 at 1:24 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What are the air/fuel sensors doing?
    Something is telling the ECM to add fuel.
    Amo-cat3 likes this.
  6. Nov 6, 2020 at 3:16 AM
    joe toy
    stock
    Yes took the fuel pressure from the rail . have to double check up stream sensors again thanks guys
  7. Nov 6, 2020 at 3:36 AM
    j8food
    j8food Well-Known Member
    Jay
    2009 Tacoma TRD Off Road
    Can you read injector duty cycle? A vehicle that old with low miles might have some clogs.
  8. Nov 6, 2020 at 5:32 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    If fuel pressure is good, next place to look is a vacuum leak. Start at the MAF sensor and go from there. Side note, make sure the O2 sensor you used is Denso.
  9. Nov 10, 2020 at 10:35 AM
    joe toy
    stock
    02 -s1 3.25 02 sb1 -s1 3.24 map 3.87 fuel long term 39.80 short is 15.00 checked all the injectors checked vacuum lines tour intake back off checked it a 2 time but it still acts like vacuum smoked it twice didn't see nothing water and brake clean but at 2500 or higher fuel terms go to long 3.86 short -1.30 and idol is perfect
