08 Tacoma does not start after it has been driven, no sound when turning the key
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Todd2425, Aug 17, 2017.
  1. Aug 17, 2017 at 7:38 AM
    Todd2425
    Todd2425 [OP] Member
    Todd
    2008 Tacoma
    I think someone must have posted this somewhere before. My Tacoma starts right up in the morning, but if I drive for a while and turn it off, I get nothing when I try to restart. No clicking sound, radio comes on and power is there. Need to keep trying until it starts. Suggestions? Anyone else had this problem in the past.
    Thanks
  2. Aug 17, 2017 at 7:43 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Sounds like the starter
    Tex-Tac and JaxJim like this.
  3. Aug 17, 2017 at 7:44 AM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    Also check starter relay. If it gets hot and stops working it might be failing.
    lynyrd3, Tex-Tac and taco2010trd like this.
  4. Aug 17, 2017 at 7:52 AM
    Todd2425
    Todd
    2008 Tacoma
    Thank you, I will check that.
  5. Aug 17, 2017 at 7:54 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Starter I believe would click I'm thinking fuel pump
  6. Aug 17, 2017 at 7:55 AM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    Check the easy stuff first:
    • Cables hooked up nice and tight.
    • Battery terminals corroded?
    • Vehicle in Park (have you tried starting it in Neutral?)
    • When it starts, does the starter sound like it's working really hard to turn the engine over?
    • Relays/fuses good?
    If those aren't the problems, then I'd also think about replacing the starter. If that doesn't fix it, then maybe you have a short somewhere in your starter circuit. But we'll cross that bridge if we come to it.
    taco2010trd likes this.
  7. Aug 17, 2017 at 7:57 AM
    Todd2425
    Todd
    2008 Tacoma
    Ok, have not check all of that so I have some work to do, thank you and will let you know what happens.
    TacoTRD78 and taco2010trd like this.
  8. Aug 17, 2017 at 9:07 AM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
  9. Aug 17, 2017 at 12:46 PM
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    Had a starter go out like this on a VW a long, long time ago, when hot would not make a sound.
  10. Aug 17, 2017 at 2:02 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    If it happens again before you figure it out, try jumper cables. If it starts right up, then I'd say the battery is on it's way out.
  11. Aug 17, 2017 at 2:20 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Could be the key immobilized. Had this issue with a chevy Colorado before. Would start fine and run great. Shut it off and try to restart, nothing.
  12. Aug 17, 2017 at 3:33 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Have autozone check your alternator, battery, and starter
  13. Aug 17, 2017 at 4:14 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Here's a quick tip.
    Next time, as you mentioned, after driving around then stopping and turning off your truck, try starting it again. If nothing happens (as you previously stated) no clicking, no start, etc. tap all around on the starter with a small hammer or large wrench a few times then try starting it again.
    If it starts then more than likely it is the starter and needs to be replaced. The majority of the times once the starter outlast it's function, the
    windings inside the starter start to get stuck (due to over the years of dirt, rain, heat, etc.) especially if it's hot, needs to cool down some to loosen up.
    Good Luck.
  14. Aug 18, 2017 at 5:51 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Not trying to be a dick, but that makes no sense at all.
    The starter solenoid could be sticking or the solenoid contacts could be worn out. I had to replace mine this morning on a 2012.
    Maybe the remote chance that the armature bearings / bushings are worn causing the starter to drag.
    Windings are just wire, they don't stick.
  15. Aug 18, 2017 at 6:05 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Try starting it in Neutral. Could be the Safety Switch is going out.
