'08 TRD Sport Rear End question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CAWEBB1, Jan 10, 2012.
  1. Jan 10, 2012 at 7:46 AM
    CAWEBB1
    CAWEBB1 [OP] Member
    Andy
    Houston
    08 TRD PreRunner Sport
    Level Kit, Flow Tech Exhaust, Kenwood DNX6960 w/ back up camera, MB Chaos Rims 17X8.5, 265/70/17 Firestone Destination AT,
    Does anyone have problems with hearing a popping sound from under there 08' TRD Sport? Maybe from the drive shaft and is usually only when you backup or take off at low speeds.
  2. Jan 10, 2012 at 8:07 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    How many miles are on the LSD oil?
  3. Jan 10, 2012 at 8:08 AM
    CAWEBB1
    CAWEBB1 [OP] Member
    Andy
    Houston
    62,000
  4. Jan 10, 2012 at 8:09 AM
    GP3
    California
    4X4 TRD Off Road
    You should have changed the oil 32,000 miles ago (every 30,000 miles).
    Change the oil and see if it still makes the noise.
    Make sure you use LSD oil.
  5. Jan 10, 2012 at 8:11 AM
    CAWEBB1
    CAWEBB1 [OP] Member
    Andy
    Houston
    what oil do you suggest?
  6. Jan 10, 2012 at 8:13 AM
    GP3
    California
    4X4 TRD Off Road
    I will let someone else help you out there. I'm not familiar with the Toyota LSD rear.
    Personally, I would get it from Toyota.
  7. Jan 10, 2012 at 8:17 AM
    GP3
    California
    4X4 TRD Off Road
  8. Jan 10, 2012 at 8:26 AM
    CAWEBB1
    CAWEBB1 [OP] Member
    Andy
    Houston
    Thanks for your help. I need to get it done quick.
