08 Tundra seats fit in my 08 Taco???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MokuNui808, Aug 22, 2011.
  1. Aug 22, 2011 at 6:45 PM
    MokuNui808
    MokuNui808 [OP] 808ALLDAY
    Jordan
    Hilo
    2013 DCSB
    was curious if anybody would know offhand or from experience if the seats from an 08 tundra would fit in my 08 standard cab taco. i know the newer tundras are bigger...but ive seen seats from an FJ fit in a standard cab, so just figured id ask.
    thanks guys!
  2. Aug 22, 2011 at 11:28 PM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    anhting is possible with enough work, i recently welded up some brackets to put 98 honda civic seats in an old ass ranger for a friend of mine. pita though to build new brackets that were solid enough to be safe. if you do it make sure you use grad 8 or better for hardware and mount the belts directly to the truck not the seat that way if the seat does happen to some loose in a wreck you dont become a passenger on it.
  3. Aug 22, 2011 at 11:49 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Doubt it.
  4. Aug 23, 2011 at 9:39 AM
    Fodder4U
    Fodder4U Well-Known Member
    Mark
    The Colony, TX
    2011 SR5 Access Cab 4x4 Stock for now.
    So are the Hennessey Venom seats.
  5. Aug 23, 2011 at 9:42 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    And they add 20 hp. If you can get the Bugatti Veyron exhaust tip, +50 hp and it'll sound like an open header V8 :D
  6. Aug 23, 2011 at 9:21 PM
    MokuNui808
    Jordan
    Hilo
    2013 DCSB
    yeah, been looking at another set of aftermarket seats and theyre too narrow, so i would have to extend the reach of the bracket with some type of hardware. but, thanks for the info, now i know for sure grade 8! haha. but yeah, seatbelts are mounted directly to my cab. :)
    yeah, i figured that, but was hoping they might fit cuz the center console in the tundra is alot wider. is it not? but i had a bench in my truck so i wouldnt need to worry about a console anyway. :) thanks tho! :)
