08 vs 12 rear diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chadabear, Jan 31, 2018.
  1. Jan 31, 2018 at 11:02 AM
    chadabear
    chadabear [OP] Well-Known Member
    Chad
    Louisiana
    2018 DCSB 4x4
    2008 DC 4.0 P-Runner
    My rear diff after 198k miles is going out, the limited slip is making horrible popping noises when I turn at slow speeds left and right.
    I located a 2012 totaled locally with 58k miles, non locker like mine that I could possibly get as a direct swap. Anyone know if there were any significant changes between the two that I should be aware of??
  2. Jan 31, 2018 at 11:09 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    If it's an open diff it should bolt right in. Make sure the gear ratio is the same. I'm not positive if there was a difference between 4 and 6 cyl but I'm sure there is. IIRC It's an 8.4 open or 8.0 locker. So ultimately, match the ratio and you should be good to go.
  3. Jan 31, 2018 at 11:17 AM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    I believe they went from a mechanical LSD to a brake actuated"limited slip" through abs. Not sure if that matters for bolting it up, but I'd assume if your 08 didn't have the electronics to support the brake actuated limited slip you'd essentially have a completely open diff. I could be wrong on the years they switched, look into it
    This is why earlier Tacoma's (trd sport) needed the gear oil additive (lsd) and the newer ones didn't need the additive.
  4. Jan 31, 2018 at 11:43 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    it should bolt right in, but you will loose the mechanical LSD with in your current diff.
    You might look into just replacing the clutchpack / springs in your current diff.
  5. Jan 31, 2018 at 1:06 PM
    chadabear
    Chad
    Louisiana
    2018 DCSB 4x4
    That's what I was thinking. I know for a fact mine is mechanical. Wasn't so sure about the newer ones.
  6. Jan 31, 2018 at 1:08 PM
    chadabear
    Chad
    Louisiana
    2018 DCSB 4x4
    I'm pretty mechanically inclined. I own an equipment repair shop and work on light/have equipment for a living. Is this a job that can be done at home, or is it something highly recommended take to a professional? Saying the gears are ok, and all it will be is swapping clutches and bearings..
