08 won't start after reconnecting battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rhoni T, May 1, 2016.
  1. May 1, 2016 at 1:56 PM
    Rhoni T
    Rhoni T [OP] Member
    After having to replace a wheel bearing and disconnecting the battery as the Chilton said to do. I can now not get my truck started. It tries but not starting. Any ideas.
  2. May 1, 2016 at 1:59 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Did it start fine before you disconnected the battery? Welcome to TW by the way.
    tcBob likes this.
  3. May 1, 2016 at 2:01 PM
    Rhoni T
    Rhoni T [OP] Member
    Thanks. Yes, perfectly. Only issue was wheel bearing.
  4. May 1, 2016 at 2:01 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Maybe you didn't connect the battery right? :notsure: Disconnect it and connect it again.
  5. May 1, 2016 at 2:03 PM
    Rhoni T
    Rhoni T [OP] Member
    I sure hope that wasn't a girl joke. I've disconnected and reconnected 3x's now
  6. May 1, 2016 at 2:04 PM
    travistheone
    travistheone Well-Known Member
    2012 black sport double cab
    check fuses. You messed something up.
    12TRDTacoma likes this.
  7. May 1, 2016 at 2:04 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    I'm actually being serious... I have no idea why it won't start now. What happens when you turn the key? Does it click once or nothing? Do any dash lights turn on?
  8. May 1, 2016 at 2:07 PM
    Rhoni T
    Rhoni T [OP] Member
    Sorry a little touching about my being a girl and working on my own truck.
    It acts like it is trying to start. Everything comes on like normal. I've never had to crank on this truck
  9. May 1, 2016 at 2:08 PM
    eon_blue
    Azusa, CA
    How old was this battery? It may have just been on it's last legs. If everything is connected properly, try jump starting it and see if that helps
    Simon's Mom and robssol like this.
  10. May 1, 2016 at 2:09 PM
    Rhoni T
    Rhoni T [OP] Member
    Battery replaced in Jan 2016.
  11. May 1, 2016 at 2:10 PM
    eon_blue
    Azusa, CA
    hmm...well, you never know, sometimes you just get a bad battery (has happened to me before) or maybe it was drained at some point, somehow. Either way, if you try jump starting it and it still won't crank, you can at least rule out the battery as the cause.
  12. May 1, 2016 at 2:10 PM
    TOY4JMEBOOZE
    TOY4JMEBOOZE Well-Known Member
    Winchester, CA
    2018 Chevy Tahoe
    You may have connected the terminals wrong, or maybe the way you connected them drained your battery. Have someone jump start you and keep the truck running. Let us know what happens.
  13. May 1, 2016 at 2:11 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    out of gas?
  14. May 1, 2016 at 2:12 PM
    eon_blue
    Azusa, CA
    Oh and if it does start up when you jump it, probably means your battery got drained so let it run for 20 minutes or so to recharge it
  15. May 1, 2016 at 2:16 PM
    Rhoni T
    Rhoni T [OP] Member
    Plenty of gas, maker of fact it's full.
  16. May 1, 2016 at 2:31 PM
    Rhoni T
    Rhoni T [OP] Member
    started!! had to give it gas, which I've never had to do.
  17. May 1, 2016 at 2:31 PM
    eon_blue
    Azusa, CA
    Did you jump start it? Or just gave it gas while trying to start it normally?
  18. May 1, 2016 at 2:34 PM
    Rhoni T
    Rhoni T [OP] Member
    While trying to start it. Like I said it was trying to start. Guess it needing a little fuel.
    DustStorm4x4 likes this.
  19. May 1, 2016 at 2:38 PM
    eon_blue
    Azusa, CA
    Glad to hear you got it running, though having to give it gas to get it cranking isn't normal...may be time to change out the spark plugs if they haven't been done in awhile? That could be the case and it's a relatively cheap and easy DIY fix if you're handy with a wrench.
    Toyota uses copper plugs which are supposed to be switched out every 30k they say...though a lot people usually run them longer than that
    theredofshaw likes this.
  20. May 1, 2016 at 2:46 PM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    That's for the v6 the i4 gets plugs for 100k
    eon_blue[QUOTED] likes this.
