08's be prepared. Suggestions on rear spring leafs.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mvega1969, Feb 26, 2008.
  1. Feb 26, 2008 at 3:44 PM
    mvega1969
    mvega1969 [OP] Well-Known Member
    Laredo
    '17 Tacoma DC LB 4X4 TRD Off Road.
    Worst case scenario... if 08's are not included by the end of the year (or never) on our most loved TSB (rear spring leafs -harsh ride-) what will be the best option (links) to strengthen our rear suspension to have a greater payload? and definitely no bottoming out.
  2. Feb 26, 2008 at 3:48 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    If you only occasionally need some extra support, I'd be looking at the air bag route, that way you can keep your cushy ride and flip a switch when you need to tow or load up the bed.
  3. Feb 26, 2008 at 3:48 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    IMO, an AAL would be similar to what they're doing with the TSB. Creating a 4 leaf pack out of your existing 3 leaf pack.
  4. Feb 26, 2008 at 5:10 PM
    jkib
    jkib Member
    08 Tacoma DC SB
    Bilsteen 5100's, Weston steps
    I'm thinking of supersprings. Anyone have experience with these?
  5. Feb 26, 2008 at 5:50 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    I suppose trading them in on I4 5 luggers with properly designed suspensions isn't an option? ;)
  6. Feb 27, 2008 at 8:28 AM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    2000# cap for about $300 with good ride un-loaded. I just hope the 08's get added for the TSB. That's $300 I feel I already paid Toyota with the tow package!
    I'm about ready to hook up to the trailer and see what happens with my truck after reading all this.
    Let us know if you put them on and how you rate them. Also wondering about your westin bars. What model and do they ride up close to the truck or stick down aways? Thanks
  7. Feb 27, 2008 at 8:30 AM
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars, Rocky Mounts bike mount, JVC MP3 Head Unit, TRD Cat Back Exhaust, Rigid Industries front and rear light pods, dual HAM radio with remote mount heads.
    I'm considering Roadmaster Active Suspension as you don't sacrafice the ride like you would with adding supersprings and such. Much cheaper than airbags as well. I personally am on the fence though because I don't have problems with my 05 and squatting like others have said and I pull a pretty big trailer with a weight distribution hitch set pretty light.
    http://www.activesuspension.com/
  8. Feb 27, 2008 at 9:30 AM
    4x4x4trd
    North Texas
    After purchasing the TRD and tow package according to the Toyota owners manual for my '08, V6, auto, access cab I should get the following performance.
    1. trailer tongue load weight of 650#.
    2. Cargo weight rating of 905# load in the bed centered over the rear tires with two adults riding in the truck.
    3. GVWR of 5350#
    4. Vehicle capacity weight of 1205# including weight of driver, pass., and cargo.
    The wording of #2 and #4 is somewhat confusing?
    If my truck doesn't give me this performance without bottoming out then how can Toyota continue to be putting weak three leaf springs under them and not honor the TSB? To many lawyers in the world to have that kind of attitude. I'm sure the 08's will be added unless they have indeed beefed up the 3 leaf's as some on here have suggested.
  9. Feb 27, 2008 at 9:33 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Might want to consider LightRacing's Jounce Shocks in the rear. Stock ride until the last 3" of suspension travel and then you get the extra rebound. Pricey, but nice product.
  10. Feb 27, 2008 at 10:03 AM
    j4x4ar3
    Jay
    Austin, TX
    905# of load??? wow.. did they change the specs for the 08? Payload is supposed to be 1300# or are they quoting that the second adult weighs 400#??? Payload capacity and tow capacity are based on full fuel tank and a single driver. Also no where in the earlier models did they state that the TRD package was required to increase payload. I did note in another post somewhere (maybe not this forum) that the Toyota web site did change and stated now that the TRD OffRoad package was required to hit the 650# tongue load. Something isn't right though because it doesn't list any restrictions on the tow capacity which still lists at 6500#. Anyone who tows anything knows that at least 10% of the trailer weight has to be on the tongue to prevent the trailer from wagging it's tail (trailer sway) ... do the math and that would be 650# minimum.
    If what you're saying is correct (and Toyota's web site is correct) then they seriously need to restate the abilities of the truck. They're basically stating that you have to have the tow package (obviously) AND an expensive Off Road package option to reach the stated abilities. Soooo what about all those long bed users that can't get the OffRoad package??? At least they couldn't with the earlier models.
    Also note the following from the Toyota site: "Payload is the GVWR minus curb weight and includes weight of occupants, optional equipment and cargo, limited by weight distribution. Payload is not the Vehicle Capacity Weight as defined by FMVSS 110, which will vary according to installed optional equipment." --- That number as listed is 1360#
  11. Feb 27, 2008 at 11:00 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Don't forget the gas. We have about 130 pounds of gas in our trucks.
  12. Feb 27, 2008 at 11:20 AM
    jkib
    jkib Member
    08 Tacoma DC SB
    I bought the westin slim-line oval tubes. They look ok, but functionally not that great. They fit right up to the truck, so there's little room for stepping. There's also no stepping down to them...they mount too high, so their somewhat ackward to use.
  13. Feb 27, 2008 at 11:38 AM
    j4x4ar3
    Jay
    Austin, TX
    Mentioned that... proper math includes full fuel tank and a driver when stating towing and cargo capacities.
  14. Feb 27, 2008 at 12:03 PM
    1killerkaw
    1killerkaw Well-Known Member
    08 Silver DC LB SR5 4x4 Tow Pkg.
    Pop-N-Lock, AFE OE Replacement Pro Dry S, 20% tint all the way around, 6000k Bi-Xenon HIDs, 3" Dynomax super turbo muffler, ATC LED Limited campershell, Bedrug, Suspension TSB.
  15. Feb 27, 2008 at 1:10 PM
    4x4x4trd
    North Texas
    Just going by what the owners manual said on my specific truck combination. I don't think you need the TRD to get the tow package but the V6 is required I believe. That is just how I ordered mine.
  16. Feb 27, 2008 at 1:18 PM
    4x4x4trd
    North Texas
    I'm leaning towards the Plat. round ones. They fit up close on my '99 and helped on the door dings more than anything but the wife did like them. I haven't really noticed seeing a pair on a 2nd generation Tacoma yet. Thanks
  17. Feb 27, 2008 at 1:26 PM
    evile
    evile Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    is there a link to this tsb some where?
  18. Feb 27, 2008 at 1:38 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
  19. Feb 27, 2008 at 3:15 PM
    evile
    Orlando, Fl
    ya i found the same thing on alldata at work just after i made my post, im a ford tech so i got access to good stuffs like that =p
  20. Mar 7, 2008 at 6:43 AM
    4x4x4trd
    North Texas
    My service dept. just called out of the blue to set up the TSB on my '08. I guess they would rather have some Toyota warranty money than just having the springs set on a shelf. They had ordered the parts and then gotten back to me and said the '08 wasn't covered yet. That was last month. I'll let you all know about the ride, height, ect.. :D
