09-11 OEM TRD HLs - TS lens de-yella'd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lurkin, Mar 9, 2012.
  1. Mar 9, 2012 at 9:51 AM
    Lurkin
    Lurkin [OP] Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Word of warning, or information, depending on your outlook. I had a leaking OEM smoked HL that I just decided to replace instead of trying to seal. Bought the HL, installed it, then looked a bit closer. Turns out that the turn signal lens color has now changed from that piss yellow color to a clear smoked color.
    IMO, it's definitely a better color, but now I had a mis-matched set. Ended up buying _another_ HL to replace the yellow TS's HL. So, if you want to do away with the yella color, a measely $500 will do that for you. If you are replacing a HL, be forewarned.
    I tried taking a couple of pics, but I couldn't get the pic to show the color difference. Overcast I think.
    Not sure if the non-smoked HLs changed or not. The parts guy, on the second HL purchase, said he'd heard this once before on the Tacoma's. Told him now he's up to 2.
