09 4.0l head gasket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Twalt87, Apr 26, 2017.
  1. Apr 26, 2017 at 9:00 PM
    Twalt87
    Twalt87 [OP] Well-Known Member
    Travis
    Vancouver island Bc
    Head gasket is leaking coolant externally on the passenger side just above the exhaust manifold.
    It's a very small weep(doesn't drop on the ground at all, just the pink build up)
    Manual calls for dropping the front diff and steering gear. Firstly if I'm going that far I'm removing the engine instead of dropping all that crap.
    Has anyone had luck leaving the oil pan on when changing the timing cover? I have done it lots on other trucks(Chevy and fords) where the seal between the timing cover and pan is silicone. Is it not the same on this?
    Why does the pan have to be pulled?
  2. Apr 26, 2017 at 9:01 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
  3. Apr 27, 2017 at 4:39 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It doesn't have to be pulled. Just need to be vigilant and careful.
  4. Apr 27, 2017 at 7:44 AM
    Twalt87
    Travis
    Vancouver island Bc
    So it is similar to the ford's then? Where the only thing you can screw up is scrapping off your bead of silicone and causing a leak?
  5. Apr 27, 2017 at 8:08 AM
    Kerrigan911
    Kerrigan911 Well-Known Member
    Dan
    05 TRD OR, AC, 4x4, V6
    im gonna be doing the headgaskets on my 05 and from what i have read, your best bet is to remove the front oil pan studs to gain clearance and avoid removing the pan
