09 Always-On Rear View Camera
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aalders, Jun 28, 2009.
  1. Jun 28, 2009 at 6:47 PM
    Aalders
    Aalders [OP] Well-Known Member
    Logan
    Dover, Delaware
    2009 Double Cab TRD off road
    Pop-n-Lock Tlailgate handle, TSB Rear Leafs, 12V bed outlet, Back up camera in mirror mod, Roof Rack, TRD Exhaust, Front Skid Plate, Running Boards, 4 100w KC SlimLites, Westin brush guard, Fog lights in the bed pockets, extra D rings in the bed, Fog light mod, seat belt chime mod, 75,000 candlepower StreamLight rechargeable flashlight
    Note:This mod is for the Independent operation of the rear view camera from the Reverse position of the transmission.
    I finally got the time to sit down and finish this mod. so here it is from start to finish.
    First thing i did was remove the peace of trim that goes over the connector for the mirror.
    here is what it looks like.
    then you need to disconnect the mirror. notice the first row of wires. wire 1 (green), wire 2 (wight), and wire 3 (red). you will be tapping into wire 1 for your +12v and then use the switch to feed the power to wire 3.
    this is the switch i used. i picked it up from Radio Shack for around $3. Notice that it has three posts on the back side. post 1 is for input #1, post 2 is the common (or the output to the mirror), and post 3 is input #2. your splice into wire 1(green) goes to ether post 1 or 3 depending on what position you want your switch to be in when your camera is always on. when you cut wire 3 (red) the lead that goes to the clip is soldered to post 2 (because that goes directly to the mirror). last you put the other end of wire 3 (red) to the last post (1 or 3 depending on what post is left after you connect wire 1 (green) to the switch)
    this is my extensions i added to the switch
    I soldered all three wires on then used shrink tube to ensure they didn't short
    this is the splice into wire 1 (green). i used a phone line tap from Radio Shack. Note: if you are not familiar with these there is no need to strip the green wire or the wire your using to tap off of wire 1. these wire taps cut into the isolation just enough to do the job and they do it well.
    here is what it looks like after all the wiring is finished. i used small crimp connectors to tie in the red wires. i also got these at Radio Shack.
    my next step was to drill the hole for the switch and the notch for the plate that keeps the switch orientated in the right direction.
    the last thing to do is install it!
    PM me with your email if you want a Video of it working... i cant figure out how to put it on here.
    here it is:
    http://www.youtube.com/watch?v=-y2O9MDViSU
    in position #1 the switch functions like its not even there, it turns on the camera when the car is in reverse. in position #2 it functions as a always on feature for the camera so that it will operate while in drive, neutral, park... whatever
    MtnClimber, eherlihy, zmac18 and 18 others like this.
  2. Jun 28, 2009 at 6:49 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Awesome man, that looks great! :thumbsup:
  3. Jun 28, 2009 at 6:50 PM
    Aalders
    Logan
    Dover, Delaware
    thanks man i wish i could show get the video of it working on here.
  4. Jun 28, 2009 at 6:51 PM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    cool... but what does the switch do?
  5. Jun 28, 2009 at 6:52 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    what is the purpose of this mod? Great write up but if somebody could explain it to me
  6. Jun 28, 2009 at 6:53 PM
    Aalders
    Logan
    Dover, Delaware
  7. Jun 28, 2009 at 6:54 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    ohh so its for your back up camera. Cool. great write up by the way
  8. Jun 28, 2009 at 6:54 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    neato... :thumbsup:
  9. Jun 28, 2009 at 6:56 PM
    Aalders
    Logan
    Dover, Delaware
    thanks guys sorry for the confusion i guess i never thought to mention what it did lol
  10. Jun 28, 2009 at 6:58 PM
    Incognito
    VA
    Definitely bookmarking this! :)
  11. Jun 28, 2009 at 6:59 PM
    Aalders
    Logan
    Dover, Delaware
    thanks for the rep beastly!
  12. Jun 28, 2009 at 7:26 PM
    Aalders
    Logan
    Dover, Delaware
    also thanks briangp for the rep
  13. Jun 28, 2009 at 7:27 PM
    Incognito
    VA
    I sent some rep. :thumbsup:
  14. Jun 28, 2009 at 7:30 PM
    Aalders
    Logan
    Dover, Delaware
    thanks guys fells good to get recognized lol. even when you do a simple mod
  15. Jun 28, 2009 at 7:43 PM
    Aalders
    Logan
    Dover, Delaware
  16. Jun 28, 2009 at 7:45 PM
    Incognito
    VA
    Shweet! :D
    You get a big :thumbsup: on this mod!
  17. Jun 28, 2009 at 7:53 PM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Great mod! Trying to get some clarity on this, forgive my ignorance - the green is your 12v power lead, the red is the power TO the camera, and the white is your neutral?
    If not, what's white doing. I'm no electronic expert. Great mod btw.
    Does feeding that power to the cam light up anything else on your dash?
  18. Jun 28, 2009 at 7:58 PM
    Aalders
    Logan
    Dover, Delaware
    wire 2 (white) is not used at all just thought i would mention it so people could differentiate wires 1 and 3. no nothing on the dash lights up when the switch is in ether position. the way the switch is designed it isolates both circuits preventing the 12V to travel back to the truck lighting up your reverse lights and putting the R on your dash.
  19. Jun 28, 2009 at 8:07 PM
    NorCalTacoma
    NorCalTacoma Well-Known Member
    Northern California
    09 SW Dbl Cab LB TRD Sport 4x4
    Snug top with remote open,Bilstein 5100, rubber bed mat,Kmc Addicts, Duratracs,Pioneer Z150, Arc 900x6, Memphis Mojo Pro Components f&r,2x12 Memphis shallow mount subs.
    Great mod. Thanks for the writeup.
  20. Jun 28, 2009 at 8:09 PM
    EricT
    Arizona
    Ooohhh, took a second look - switch sits in the middle of the red wire. Got it.
    Nice mod! I might have to do this one.
