09 Auto Tranny "Rough" Shifting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rickochet, Jul 10, 2010.
  1. Jul 10, 2010 at 5:15 PM
    Rickochet
    Rickochet [OP] Well-Known Member
    Rick
    Kentucky
    '09 Tacoma Access 2.7 4 x 2
    Added VS Wipers, Cruise Control, DRL, Undercover SE Bed Cover
    I have had my 09 Taco since Oct. '08. It is the 2.7 auto Access with 14k miles. Recently I have noticed a minor noise/vibration when it upshifts or down shifts at minimal rpm and usually at 20. 30 and 40 mph. It is like a 5 seconds of "Brrrrrp" noise with minor vibration. I don't recall it doing this until recently. It doesn't do it at higher rpm.
    Am I hearing stuff or might there be an issue here? I bought it new and is still under warranty.
    Any info would be appreciated.
    Rick
  2. Jul 11, 2010 at 2:52 AM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    Not sure if this helps- It applies to 08 and older Tacomas.
    I noticed that yours would be a very early 09, so see if your VIN number qualifies.
    There is a TSB for "Driveline Vibration between 15 - 25 MPH"
    TSB-0132-08
    For inline 4 cylinder models 2WD your VIN would have to be earlier than 5TE*X##N*8Z499787
    The *'s and #'s are wildcards so the actual digits don't matter I believe the last 5 or 6 digits are your individual serial number and should be sequential- eg. see if yours is a lower number then the TSB applies.
  3. Jul 11, 2010 at 12:59 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    ^^ check out that TSB, and also their is a Tranny TSB from what i hear that is a reflash and helps make the shifting better.
