09+ Backup Camera PINOUT
Discussion in '4 Cylinder' started by TAC0MA, May 26, 2010.
  1. May 26, 2010 at 9:06 PM
    TAC0MA
    TAC0MA [OP] Well-Known Member
    Garrett
    Molena, GA
    07 4cyl manual TOTALED, 2010 4cyl auto
    Pioneer AVIC700bt in dash A/V receiver, K&N air filter
    Dont know if this info has been dropped here at TW or not, just thought I would share my experience.
    I have a 2010 regular cab that was prewired for the backup camera but did not come the camera module or the rearview mirror monitor. I recently purchased the camera module from someone here on TW and hooked it up to my Pioneer AVIC F700bt HU. Below is a pic of the camera harness location along with the pinouts to the camera.
    BLACK = Camera 12v +
    SHEILD = Camera 12v -
    RED = Camera Video +
    WHITE = Camera Video -
    I don't know WHAT Toyota was thinking when they engineered the color code for this, but it is what it is.....
    Now for the harness itself, the male socket goes to the camera and the female I assume goes up to where the rear view mirror monitor plugs in. I also found the the 12v power legs of the harness are not hot, I guess they get power from the rearview mirror? So I supplied power to this circuit from the HU along with my video feed up to the HU.
    Hope this helps someone!! :D
  2. May 26, 2010 at 9:08 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    good find!
  3. May 27, 2010 at 6:15 AM
    C17Guy
    C17Guy Well-Known Member
    Dennis
    Charleston, SC/ Charlotte, NC
    09 SR5 Access Cab 5 Lugger
    Readylift Kit, 245/75/16, HID's, Debadged, Kenwood DNX9960 Double Din Navigation, Image Dynamics Door Components, Pioneer Amp, Dynomax Super Turbo Muffler, Grillcraft Uppers and Lowers
    great job! i'm about to wire my pre-existing camera into my hu! thanks!
  4. May 27, 2010 at 6:24 AM
    MenaceAllen
    MenaceAllen Well-Known Member
    Eric
    Fargo, ND
    2010 Super White TRD Sport
    Alpine W505 Deck, GPS, WeatherTech Mats, Vent Visors, 18" KMC Monsters w/ Nitto Terra Grapplers, 20% Tint, Bed Mat, Eibach Coils, Blistein 5100's, Rear 1.5" AAL, Lorado Access Cover, TREX Angry Eyelids, AstroStart, 6k H.I.D's
    Is it possible to have the backup camera show in my mirror and also have it show up on my HU? I have a Alpine double DIN that will allow a back up camera view. How would I go about splicing it (if I can)?
  5. May 27, 2010 at 6:33 AM
    C17Guy
    Dennis
    yes, you can. i remember seeing a write up on it here, i'll try looking for it. but this is exactly what i plan on doing.
  6. May 27, 2010 at 11:07 AM
    MenaceAllen
    Eric
    Fargo, ND
    I will try and find it as well. If you come across it please post the link and I will do the same. Thanks!
  7. May 30, 2010 at 7:22 AM
    TAC0MA
    Garrett
    Molena, GA
    All you would need to do is tap splice into the video circuit, red and white, with an RCA cable and connect that to your HU. Leave the power circuit as it is.
  8. Oct 12, 2012 at 4:05 PM
    camper101
    camper101 Member
    '12 Tacoma Access cab TRD
    Does this mean that I run the RCA signal into both the red and white wires?
    Obviously I have no idea what I'm doing... but I'm trying to get an RCA signal (yellow video plug) into the Tacoma's rearview mirror. I have an extra camera wiring harness that I'm going to splice into.
    EDITED TO ADD: I'm basing this off the fact that I just cut a yellow RCA video cable. It seems like there's only one (copper colored) wire inside? Or is the outer silver stuff also wiring that should go to positive or negative?
    Thanks
  9. Oct 13, 2012 at 6:26 AM
    BamaToy1997
    Bill
    Navarre, FL
    RCA video cables have the signal or "positive" going through the core, and the ground or "negative" is the shield around the core.
  10. Oct 13, 2012 at 2:56 PM
    camper101
    camper101 Member
    This worked. Thanks again!
  11. Apr 26, 2013 at 11:17 AM
    WhiteTacoma09
    WhiteTacoma09 Well-Known Member
    Curt
    Florida
    09 Prerunner access cab
    ZXE Headlights Drop in k&n filter Kobalt slim toolbox Tinted 17" FJ trail edition wheels OEM foglights 265/70/17 BFGs AVS vent visors Pioneer AVH-X1500DVD
    my rear camera pinout colors are black, blue, red white. blue being (-)?
  12. Apr 27, 2013 at 4:14 AM
    sciencerabbit
    sciencerabbit Well-Known Member
    North Carolina
    2013 PreRunner
  13. Apr 27, 2013 at 8:02 PM
    WhiteTacoma09
    Curt
    Florida
    drew up this schematic for my 2009 and was wondering if this is how it is for those who have theirs working. thanks. 20130427_223551_bb88e3776ed7253b488af7a3035ac3535c53da2d.jpg
  14. Jun 2, 2014 at 5:22 AM
    CrossBonz
    CrossBonz Active Member
    Nova Scotia
    2011 DCLB SR5
    Here is the mirror pinout from my 2011. I recently replaced the stock mirror that has a 3.5" monitor with a Rydeen MV411T that has a 4.3" monitor as well as temperature display and compass (http://www.rydeenmobile.com/Backup Monitors/MV411T.html).
    For those looking to transfer the video signal from the factory mirror to another source such as this mirror or an aftermarket video screen, just adding an RCA connector to the camera wires isn't enough. The power for the factory camera loops through the mirror so when you remove the factory mirror you take away power to the camera.
    In addition to adding the RCA wires, you also need to hook up 2 jumper wires to power the camera again. Simply run a jumper (i used a 3 amp fused jumper for safety sake) from the RED reverse trigger wire to the BLACK camera power + wire, and another jumper from the WHITE/BLACK ground wire to the BLACK camera power - wire. This will power up the camera when you place the truck in reverse.
    If you're using a mirror like this you can get your accessory power (LIGHT GREEN) and ground (WHITE/BLACK) in the plug as well to power the mirror.
    Key-Rei likes this.
  15. Dec 12, 2017 at 7:55 PM
    tbird95
    tbird95 Well-Known Member
    British Columbia, Canada
    TRD sport SR5 V6 DC, LB, 4x4, Tow package
    4runner heated, signal, courtesy light side mirrors, rearview mirror w/compass, temp & backup cam w/ pop luck PL 5400, Interior lights/gauges, BHLM, grillcraft MX black. Third brake light LED swap, rear tail lights LED swap from 2011. 3" Toytec (Boss) Coil overs, rear TSB AAL Bilsteins, Light Racing UCA. TRD grill badge, VIPER Smart Start.
    So did your 2011 have a backup cam display already? I'm guessing yes. I'm trying to use my gentex 3320 (has 4.3" display w/compass and temp) I need to know how to get the compass and temp to function on factory wiring. The compass and temp wiring are just Y spliced in the header and go to the overhead console. Any idea what the rest of those wires in the pin do for the pinout pic earlier in this thread? Why would you need an rca cable etc?
  16. Dec 16, 2017 at 11:46 PM
    tbird95
    Is the mirror sending 6v to camera?
  17. Dec 16, 2017 at 11:46 PM
    tbird95
    Why is an rca cord required?
  18. Dec 27, 2017 at 4:16 PM
    tbird95
    Anyone?
  19. Apr 22, 2023 at 1:39 PM
    dpanibratets
    dpanibratets Well-Known Member
    Denis
    Vancouver, WA
    2005 DCSB soon to be with V8 1UR-FE
  20. Apr 22, 2023 at 1:53 PM
    CrossBonz
    Nova Scotia
    2011 DCLB SR5
    I’m just got notice there were replies to this thread 9 years later! I don’t recall if it’s sending 12 volts or 6 volts to the camera…I suspect 12 volts but can’t say 100%. I don’t know what the rest of the unlabelled wires do, sorry.
    An RCA cable would be required if your aftermarket stereo (or in this case, the mirror I’m using), has an RCA input for a backup camera which most do.
