09 backup camera with aftermarket HU?
Discussion in 'Audio & Video' started by bass mechanic, Feb 16, 2009.
  1. Feb 16, 2009 at 6:41 AM
    bass mechanic
    bass mechanic [OP] Well-Known Member
    colorado springs, colorado
    2009 tacoma Access cab TRD offroad in black
    none
    does anyone know if it is possible to use the factory backup cam on the tailgate with an aftermarket HU?
    i have the video in the mirror but its pretty much worthless that small and my kenwood 8120 has a rear cam input i would like to take advantage of.
  2. Feb 16, 2009 at 6:47 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    I imagine it's possible... it's an NTSC video signal I imagine... should work... me thinks.
  3. Feb 18, 2009 at 7:20 AM
    bass mechanic
    none
    ok guys io have good news, i called the company that makes the rear view mirrors and asked them for the pinout on the mirror.
    if you remove the plastic cover on the mirrir to get access to the wires you will find a 10 pin plug
    on the right side of the connector is pin 1 with a red wire, next to the left a white and several pins to the left another red i think its position 6
    the first red wire is the + cam signal the white is the - cam signal i saldered a RCA cable onto these wires and plugged that into the rear camera input
    the remaining red is the backup wire so i used that.
    i now have video on both the mirror and the aftermarket head unit. you can definitly see more detail on a 7" wide screen!
    good luck!
  4. Feb 18, 2009 at 8:01 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    hey man, thx for the heads up in a PM. can u show a pic of this? i'm still trying to picture it in my head how u can solder the rca on, but still have the use of those wires to the mirror as well.
  5. Feb 18, 2009 at 8:36 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Yeah, pictures would be awesome!
  6. Feb 18, 2009 at 10:57 AM
    rsta
    rsta Member
    Albq NM
    2000 n 2009 Prerunner TRD
    Great job man. +2 on the pics
  7. Feb 18, 2009 at 2:52 PM
    mix123
    mix123 Member
    Canada
    09 SR5
    If you cut an rca cable there are two wires....pos negative....solder to those
  8. Feb 18, 2009 at 3:30 PM
    jhodge83
    SC
    17 XLT Sport
    i understand that, but solder them onto the wire like a vamp tap? if u cut the wires going to the harness, then how do u get them to continue on to give signal to the mirror
  9. Feb 18, 2009 at 3:47 PM
    ianham
    ianham Active Member
    I'm not exactly sure on how this plug works but... you should be able to push out the two red pins. Then solder your wire onto the pin or just below it. Put the pins back into to the molex connector. Then just route it down to your head unit and it should work.
    You could also cut some of the wire loom back and then use some 3m scotchlok t-tap an then just take the video off of those.
  10. Feb 18, 2009 at 5:49 PM
    bass mechanic
    none
    i soldered because i didnt want to use a t tap it would not fit under the plastic cover so i used a stripper to strip the insulation back without cutting the actual wire, soldered to that and taped it up.
    you need to cut off the end of an rca cable and use the shield for ground and the center for + same with the backup wire.
  11. Feb 18, 2009 at 5:57 PM
    jhodge83
    SC
    17 XLT Sport
    ahh, i gotcha now...kept the wire in place, cut a chunk of insulation off the wires, and soldered the rca's to that....makes sense to be able to use both mirror AND HU
  12. Feb 18, 2009 at 6:01 PM
    bass mechanic
    none
    by the way i noticed when i plugged in the video cable to the HU with the reverse cam on the one in the mirror dims slightly due to signal loss. its not a lot but it could mean things arent as bright as they would be normally, i have not figured a way to turn off the mirror screen without killing the video all together it seems the mirror must be sending a voltage to the cam to turn it on.
    so unfortunatly you have to run both or none at all.
  13. Feb 25, 2009 at 3:08 PM
    mix123
    mix123 Member
    Canada
    09 SR5
    I have an '09 SR5 with the backup cam in the tailgate handle. No mirror. Is the plug still up in the roof somewhere? How do I access it?
  14. Feb 25, 2009 at 7:35 PM
    ianham
  15. Feb 28, 2009 at 11:46 PM
    jcdevivero
    jcdevivero Active Member
    Seattle
    '06 Toyota Tacoma TRD
    Do you guys know if a 2006 is wired for this already?
  16. Mar 1, 2009 at 8:47 AM
    jhodge83
    SC
    17 XLT Sport
    09's only
  17. Mar 1, 2009 at 8:53 AM
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    cool. thanks for the info.
  18. Mar 1, 2009 at 12:05 PM
    Jay-Hawks
    Jay-Hawks Well-Known Member
    Galveston
    09 Prerunner TRD 4X2
    Tube Step, Leather interior, XM, Bed Extender, Tinted Windows, Dynolock
    I did this mod this weekend and it works pretty good. The only draw back it the picture on the stereo headunit loses some of the picture quality.
  19. Mar 1, 2009 at 12:10 PM
    bass mechanic
    none
    yea i was actually thinking of adding a second backup camera so i can can 2 different views. i thought about using the mirror function on the kenwood so i can read license plates behind me
  20. Mar 1, 2009 at 12:14 PM
    Jay-Hawks
    Galveston
    Did you try just cutting the video wires that go to the mirror and see if that would work? I know that you had to have the mirror plugged in for it to work which makes me think that the power for the camera was going through the mirror.
