09 brake question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ElevenTenths, Jan 16, 2009.
  1. Jan 16, 2009 at 6:02 AM
    ElevenTenths
    ElevenTenths [OP] Voice of Reason
    sorry if this has been covered, search did not reveal much...
    is a slight buzzing when engaging the brakes normal? it is not on the level of an abs engagement... feels like more like a self test other cars do on the first use of the brakes. i can hear a faint whirr as one would expect from a self test... strange thing is it happens with almost every use of the brakes not just once.
    thanks.
  2. Jan 16, 2009 at 6:24 AM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    That doesn't happen on my 09 nor does what you describe sound normal for any healthy brakes.
  3. Jan 16, 2009 at 7:40 AM
    09tacoLI
    09tacoLI Well-Known Member
    long island ny
    09 off road
    Shrockworks sliders,Shrockworks Front bumper,Warn 9.5xp winch,Toytec Ult.3in,Total Chaos UCAs,AP expo Rear, Fox remote resi shocks Bud built skids,Piaa 7in,Piaa yellow plasma Off road lights.
    Ive only got 70 mi on my 09 but It doesn't make any noise I'll let you know if it does and keep us updated if you find out whats up.
  4. Jan 16, 2009 at 7:48 AM
    Joe B
    Joe B Well-Known Member
    Never a noise problem here either.
  5. Jan 16, 2009 at 7:57 AM
    IRISHDEVIL
    IRISHDEVIL Well-Known Member
    Does the Sound come from under the dash? If so it sounds like the brake switch is bad. Let us know were the sound is comeing from.
  6. Jan 16, 2009 at 8:28 AM
    ElevenTenths
    a second or two of pulsing in the pedal... associated with a very faint whirring from under the hood, not under the dash.
  7. Jan 16, 2009 at 9:42 AM
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    Sounds like ABS is kicking in. Are you on snow or ice? My ABS is quite sensitive on snow/ice.
    Aside from that, the only buzzing I get is when I try to drive without fully releasing the park break.
  8. Jan 18, 2009 at 6:03 AM
    ElevenTenths
    Interesting update...
    I can recreate the symptom without the truck running/moving.
    Get in, turn key to "on" but do not start truck, one can hear the faint whirring pump sound. Turn key to off, pump brake a few times, keep foot on brake, turn key back to "on" but do not start... again the whirring sound and slight buzzing in the brake pedal while the "pump" is running.
    Is the brake boost in our later model tacomas pump vice engine vaccuum driven? if so, this would explain the symptoms and put it in the normal(ish) column...
  9. Jan 18, 2009 at 2:57 PM
    brendazzle
    brendazzle Active Member
    San Jose, CA
    09 Timberland Tacoma 4x4 OR Access Cab
    3" readylift sst
    I don't have that on mine, brakes are quiet; especially when stopped.
    09 4x4 a/t access cab v6
  10. Jan 18, 2009 at 3:40 PM
    Liquidity
    Liquidity OIF Vet
    09 Prerunner TRD sport
    I have about 1,000 miles on my 09 with no noise at all
  11. Jan 19, 2009 at 9:06 AM
    ElevenTenths
    Es Normal... according to our servicing dealer:
    There is indeed an electric pump that is responsible for the brake boost and that is what I was detecting. I checked my brake system is there is no vacuum accumulation drum/diaphragm against the firewall.
    For those wishing to verify yours is working.... park somewhere quiet (such a closed garage), open the driver window, turn the key to "on" but do not start you car, you will hear the pump pressurize the system for a bit. after it stops pumping the brake should make it trigger again.
    It is always possible the dealer is blowing smoke but it all sort of fits.
  12. Jan 19, 2009 at 9:41 AM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    my brake makes that buzz noise when I stepped it on it sometimes. I thought it was normal. The buzz would vibrate to my foot, just a slight buzz, not anything crazy.. I'm going to drive it out for lunch and let u guys. my brakes works thou...
  13. Oct 26, 2010 at 1:41 PM
    Geode
    Geode Well-Known Member
    Illinois
    09 4WD TRD
    I bought a new 09' 13 months ago. Low and behold today it started making this noise, mostly when applying the brakes but it also happens when in park or at a stop. But almost always when I hit the brakes. Sounds like a servo motor. Been trying to avoid taking it to the dealer for the brake pedal surgery and ECU update. But if this keeps up sounds like I'll need to get it in for service....
  14. Oct 26, 2010 at 2:26 PM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    I have heard a noise like you might be describing- sounds kind of like the windshield wiper motor. Only ever heard it after first brake application when pulling out of driveway. Also, I experience quite a bit of pedal sink when stopped at lights. I know this is "normal" for Tacos, but it seems excessive in this case. I had an '07 TRD and it did not exhibit nearly as much pedal sink. Wondering if I have a vacuum leak? Also, how would you know if you have leak in master cylinder? In any other vehicle I would be at the dealer right now demanding replacement of my apparently leaking master cylinder.
  15. Oct 26, 2010 at 2:30 PM
    Geode
    Illinois
    09 4WD TRD
    Yeah I'll keep an eye on it. It's not an intermittent problem, It happens whenever I apply the brakes, as well as at other times......
    Any chance it is throwing a code? I've been looking for an excuse to get a reader :)
    Did anything get resolved by the original poster?
    Thanks
  16. Oct 26, 2010 at 2:42 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Mine buzzes and clicks sometime when starting the truck when boosting itself for wathever reason. Brakes work fine so no problem there.
  17. Oct 26, 2010 at 2:46 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    What you are describing is the ABS system calibrating itself. Perfectly normal.
  18. Oct 26, 2010 at 3:05 PM
    Geode
    Illinois
    09 4WD TRD
    That works for me, but why did it start after 13 months of ownership? And will it ever stop? ;) On my drive home it became quite irritating, every time I apply the brakes I get this loud servo sound for a few seconds.
    I cleaned the interior recently, first time....Should have known it was a bad idea.
  19. Oct 26, 2010 at 5:15 PM
    supralight
    Dan
    Earth
    maybe a leak somewhere so the booster has to overcome the leak everytime you press the brake pedal?
  20. Oct 26, 2010 at 5:17 PM
    TexasTacoma37
    yours does not sound normal I would definitely take it to the dealer.
