09 Coolant Overflow Tank
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hotajax, Feb 17, 2022.
  1. Feb 17, 2022 at 10:16 PM
    hotajax
    hotajax [OP] Well-Known Member
    09 TRD Off Road
    There's short hose that runs between the radiator and overflow tank. Mine is leaking at the connection. So as far as I can see there's no hose clamps for this hose. Seems like I should and least put some Permatex there. But - which non-hardening Permatex will work with antifreeze? Thanks.
  2. Feb 17, 2022 at 11:13 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    No permatex is needed, if it's leaking either replace the hose or the radiator or the tank whichever is broken cracked or split.
    Dm93 and muddog321 like this.
  3. Feb 18, 2022 at 5:03 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Many people use a small Zip Tie at that location.
  4. Feb 18, 2022 at 5:05 AM
    rtilton12
    rtilton12 Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    zip tie it. it seems normal cause all 2nd gens do it but my coolant is NEVER low. zip tie!
  5. Feb 18, 2022 at 5:25 AM
    hotajax
    09 TRD Off Road
    Thanks buddy. Much appreciated
