09 cruise control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by j31driver, Aug 12, 2010.
  1. Aug 12, 2010 at 6:50 PM
    j31driver
    j31driver [OP] Active Member
    chris
    upstate NY
    09 Tacoma
    I can't find the clutch switch wire to connect to the clutch switch. Can anybody help me with this?Does anybody no what color the wires are? I ordered the parts the other day and the rest of the job took 10 minutes tops.
  2. Aug 13, 2010 at 4:53 AM
    j31driver
    chris
    upstate NY
    09 Tacoma
    Nobody out there whos done this? I searched but the site but I can't find out exactly.
  3. Aug 13, 2010 at 5:06 AM
    Reaper22
    Reaper22 Well-Known Member
    Palmyra Missouri
    SR5 Tacoma
    Radient Red, Red Grille, Debadge'd, Blacken'd Headlights, DTRL's, Cruise Control, Fog Lights, 2 1\2" suspension lift, 285\75\16 Nitto Dune Grapplers, Pioneer Premier DEH-P510UB stereo, Pioneer 3 way fronts with factory tweeters & Kenwood tweeters, Kenwood truck boxes behide seats with 8" subs in each, Wet suit like tacoma seat covers
    I done this on my 06 reg cab but look and see if this helps, It should be a white connector tapped to the wire harness just above clutch peddle assembly..
    http://www.toyotanation.com/forum/showthread.php?t=171992&highlight=cruise
  4. Aug 13, 2010 at 5:32 AM
    j31driver
    chris
    upstate NY
    09 Tacoma
    Reaper22,it was your write up that I went by but for the life of me I can't find this connector. I'll keep looking but it is pretty tight.
  5. Aug 13, 2010 at 5:33 PM
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    If you look straight up there is a large wire loom coming from the steering collum and it should be tapped to that.. I think reading some where that some of the later modles did not have this wire and had to run it back to the ecm.. But I would think if everything else was there this clutch wire should be there as well.. If you go down the road will the cruise light come on in the dash when you turn the cruise on, if not you may have to find the write up on how to get the wires to the correct pin on the ecm.. Good Luck Man..
  6. Aug 13, 2010 at 7:41 PM
    j31driver
    chris
    upstate NY
    09 Tacoma
    No the cruise light does not come on. I don't have a good feeling about this.
  7. Aug 13, 2010 at 7:42 PM
    j31driver
    chris
    upstate NY
    09 Tacoma
    Thanks for your help Reaper22.
