'09 DC off road w/ factory bluetooth question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slab, Mar 27, 2009.
  1. Mar 27, 2009 at 2:31 PM
    Slab
    Slab [OP] Active Member
    West Virginia
    09 TRD Off road double cab
    '09 double cab off road owners w/ factory blue tooth- Where is your blue tooth button installed? The instruction manual from Toyota has the installation going in the same spot as the DAC buttion (2nd button to the left of the steering wheel). Just curious if anyone has it in a different place. If it's 2nd from left, where is your DAC button?
    How about the mic? Instruction have it going at the seam between the center radio and steering above the little change tray.
    I'm hoping to install this weekend. Any help would be appreciated.
  2. Mar 27, 2009 at 3:52 PM
    Chip
    Chip Member
    Long Beach, CA
    09 Tacoma 4x4 Access Cab
    3" Icon Coilovers
    My taco came factory with the BluLogic system. and it came installed in the second position, but I don't have the DAC system. It shouldn't matter which knock out panel you use. And they did install the mic just above that change compartment by the audio system.
  3. Mar 27, 2009 at 4:21 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    My '09 DC TRD Offroad came w/ factory bluetooth, and I have 3 buttons on the steering wheel...
  4. Mar 27, 2009 at 4:22 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    x2
  5. Mar 31, 2009 at 5:45 AM
    Slab
    West Virginia
    Anybody with an Off road Double Cab with Blue tooth other than in steering wheel?
  6. Mar 31, 2009 at 7:46 AM
    bajamoon
    STEVE
    Whittier
    from the factory i think it comes that way, take a picture so people here can see it. it might be something the dealer added after the fact. look on the sticker that was on your car when you bought it, it should say what it is.
  7. Apr 2, 2009 at 12:15 PM
    Slab
    West Virginia
    Do you have the JBL stereo?
