09 DC OR Starts, Sputters and Shuts Off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoRocco, Oct 16, 2022.
  1. Oct 16, 2022 at 6:36 PM
    TacoRocco
    TacoRocco [OP] Well-Known Member
    Niagara Region, ON
    09 Tacoma TRD OffRoad
    OME 2 inch lift
    Question to the group.
    09 Tacoma OR DC. Around 300k on the odo. Regularly and religiously service the vehicle. Just did a major service in the spring of 22. New plugs, fluids, battery, etc etc.
    A few times this year I go to start the vehicle and it starts up and then sputters off. It runs for a second or two and then just shuts off. Couple times cranking it like that it starts and then sputters and decides to stay on. Last couple of times it happened was after changing the oil on my driveway, with the trucks nose slightly slanted downwards. This is first time it happened on level ground, and not after an oil change.
  2. Oct 16, 2022 at 6:56 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    clean the throttle body?
  3. Oct 16, 2022 at 7:03 PM
    TacoRocco
    Niagara Region, ON
    OME 2 inch lift
    Did a quick clean of it this spring. Nothing too detailed.
  4. Oct 16, 2022 at 7:05 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Just based on your symptoms it sounds like the fuel pump could be on it's way out, a fuel pressure test could confirm.
  5. Oct 16, 2022 at 7:05 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    No engine light on at all?
    Has there ever been one on in the passed?
  6. Oct 16, 2022 at 7:07 PM
    TacoRocco
    Niagara Region, ON
    OME 2 inch lift
    Nope. Nothing.
  7. Oct 16, 2022 at 7:08 PM
    TnShooter
    Deogee
    STOCK
    Then I agree with @Dm93
    Sounds fuel related.
    TacoRocco[QUOTED][OP] likes this.
  8. Oct 16, 2022 at 7:08 PM
    tacopeter
    tacopeter My truck isn't modded. It's well optioned.
    Peter
    Washington State
    21 DCLB TRD OR
    OEM+
    Fuel filter or pump would be my guess.
    TacoRocco[OP] likes this.
  9. Oct 16, 2022 at 7:09 PM
    TacoRocco
    Niagara Region, ON
    OME 2 inch lift
    Been using Costco fuel last couple years. I gotta feeling its fuel pump/filter related. Looked at replacing filter this spring and found out its in the tank.
  10. Oct 16, 2022 at 7:15 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
  11. Oct 16, 2022 at 7:18 PM
    TacoRocco
    Niagara Region, ON
    OME 2 inch lift
    BlkDakDave[QUOTED] likes this.
  12. Oct 16, 2022 at 7:20 PM
    TnShooter
    Deogee
    STOCK
    Might as well do the pump if you do the filter.
    It’s on the bottom of the pump.
    Thanks a lot Toyota. :rofl:
