09 DCSB: Belt Squeal/Slip on cold start/acceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bishop2Queens6, Mar 1, 2015.
  1. Mar 1, 2015 at 1:40 PM
    Bishop2Queens6
    Bishop2Queens6 [OP] Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Hello all,
    I have a 2009 DCSB with 113K on the ODO with the original serpentine belt. I found there is some belt squeal on a cold start or accelerating onto the highway with a cold engine. I inspected the belt: no chips, cracks, splits, or oil drips. Tension is good as well as far as I can tell.
    I'm just wondering if changing the serpentine belt would fix the issue or do I have a bigger problem such as some bad pullies, bad tensioner, or...?
    Any advice and recommendations are welcome!
    Thank you.
    -Bishop
  2. Mar 1, 2015 at 2:32 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    My first impression is that your belt is worn out.... They are not like the old "V" belts and can be worn out and still look good.... the secret is the depth of the belt in the "V" area. The bottom doesn't wear that makes the belt ride "higher" in the groove... Only contact you get that way is the tip of the "V"...
    Try new belt... if no change...,check all pulleys and tensioner..Check for "wobble".....don't forget the alternator.....mine froze up last year and fried a new belt... and all the pulleys and tensioner were worn and sloppy...
    Good luck man...
