09 Driveline Vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dchampn, Oct 3, 2014.
  1. Oct 3, 2014 at 11:06 PM
    Dchampn
    Dchampn [OP] EMT
    Virginia
    09 Lifted Tacoma SR5
    6" Fabtech Lift, 20" Fuel Nutz Rims, 35"x12.5" Toyo Open Country
    Hello all,
    I recently (less than 100 miles) replaced u joints and carrier bearing as I had a very noticeable driveline vibration around 30-35mph then again from 65-70mph. Though it improved slightly it is back to the original issue. It is only felt under acceleration, immediately after letting off gas it goes away. Any help would be awesome!
    Thanks in advanced
  2. Oct 3, 2014 at 11:38 PM
    GreeneMan
    GreeneMan En serio?
    Robert
    Asheville, NC
    09 Base 4x4
    Cooper A/T LEER Campershell Shrockworks Front/Winch Fox 2.0 rem. res Front and rear. Icon AAL 3pk
    I had the same problem with my 09 a few years ago. It was still under warranty so I took it in and they replaced the shaft. I'm not sure if it was just faulty U joints or the shaft itself. However, once replaced the vibrations went away.
  3. Oct 4, 2014 at 1:24 AM
    Dchampn
    Dchampn [OP] EMT
    Virginia
    Did they replace the whole shaft or just a section of it?
  4. Oct 4, 2014 at 6:52 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Did you 'mark' the driveshaft before replacing the ujoint?
    If you don't get the driveshaft back in the exact placement (ear to ear), can create vibes.
