09 engine break in?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zero niner, Aug 22, 2008.
  1. Aug 22, 2008 at 11:41 AM
    zero niner
    zero niner [OP] romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    Hello,
    I usually like to welcome myself to new forums with a probably beaten to death thread so here goes.
    Any recommended break in procedure for the a new 09 engine? I just used the heat cycle method with my new Triumph Speed Triple and that process goes against the manufacturer's break in procedure. Where you push the engine through modest accel/decel short trips all the while changing the oil. I know motorcycles and autos are different so I thought I'd ask. Thanks in advance for your advice and insults!
    Rob
  2. Aug 22, 2008 at 11:49 AM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    I was told that before I use the cruise to have 1000 miles on my 09 first. I figure as tight as these Taco's are it will take it a long time to really get broken in but I must say....mine is already getting over 21mpg around town so I cant wait to get it out on the highway this weekend for a road trip. Currently I have 400 miles on it.
  3. Aug 22, 2008 at 12:02 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Thanks for the reply, what you have done to secure your tailgate and camera? I'm worried about theft of these items...
    Rob
  4. Aug 22, 2008 at 1:03 PM
    tdm156
    San Antonio, TX
    Well nothing so far but I am having an undercover installed today that will lock but not sure if thats enough to keep the tailgate in place or not. If the come out with a pop lock for this one with the camera I will probably get that one for when I am traveling. While I am at work I really dont have to worry about things so much and I am at work more than anywhere.
  5. Aug 22, 2008 at 1:05 PM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    i thought the truck comes in break-in oil so it is already broken in.. maybe I'm wrong.
    i read it somewhere here
  6. Aug 22, 2008 at 4:04 PM
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    I've used my cruise control from day 1.
    Do the hose clamp on your tailgate!
    My undercover should be here soon, the instal looks pretty easy from the pdf on their site. Where is that brown truck at?
  7. Aug 22, 2008 at 4:47 PM
    tdm156
    San Antonio, TX
    I have used the cruise a couple times myself and plan to use it tomorrow. I had my undercover installed today and looked really easy. Make sure to "tuck" the rubber seal at the cab once you get it installed so it seals off right. They also put some little clear protector dots on the cab where the rings are just to prevent them from scratching the cab in the even that they did touch for some reason. Good luck with yours and we will send that Brown truck your way
  8. Aug 22, 2008 at 5:13 PM
    Fish Tacos
    Fish Tacos Active Member
    Conn
    2009 Double Cab TRD Off-Road
    tdm - any pics of your taco with cover?
  9. Aug 22, 2008 at 5:16 PM
    tdm156
    San Antonio, TX
    No not yet. I just got it put on 3 hours ago and its been raining....as soon as I get some clear weather this weekend I will get pics posted.
  10. Aug 22, 2008 at 5:25 PM
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    Yeah those are important or just dont use the rings, my old taco had scratches from those things, I took them off after a few years but had to sand, prime and use touch up paint.
  11. Aug 22, 2008 at 5:30 PM
    tdm156
    San Antonio, TX
    I thinking about what I can use in their place that would be safer to the finishes. I was almost thinking about a zip tie or something like that but would need to make the hole a little bigger.
  12. Aug 22, 2008 at 11:04 PM
    MikeS.
    MikeS. Well-Known Member
    Far Eastern WVa
    2008 DC LB 4x4 in Speedway Blue.
    Undercover bed topper, Nerf style step bars, Python alarm, Ham radio with 250 watt amp and chrome wheel well bling.
    Check my gallery I think I have some shots of mine with the Undercover.
    Yep, they are in there.
  13. Aug 23, 2008 at 2:21 PM
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    I installed my cover today. Took a while to get it lined up fairly close to what specs call for. I put the rings in, they aren't close the cab at all.
  14. Aug 24, 2008 at 8:52 AM
    botayota
    botayota Well-Known Member
    New England
    2023 Tacoma TRD Sport 4x4 Access Cab
    Blue Crush Metallic
    Cany anyon explain to me what an undercover is and where I can buy one?
    Tkx,
    BY:D
  15. Aug 24, 2008 at 10:43 AM
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    Undercover = tonneau/hard cover for the bed of your truck.
    4wheelonline has them for 658 shipped. Call them when you order to get the price, ask about the lower cost mentioned on their website.
