09 manual clutch replacement help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IP TACO4x4, Feb 16, 2018.
  1. Feb 16, 2018 at 11:34 AM
    IP TACO4x4
    IP TACO4x4 [OP] New Member
    2009 Tacoma TRD off road
    Hello ladies and gentlemen. I'm in a bit of a bind. I'm trying to removing the transmission from my 09 tacoma 4x4 6speed manual and have run into a problem. I've removed 11 bolts that holds the bell housing on and I'm worried befor I start to yank on it that there might be some other wire/etc that I need to disconnect. I need some direction any help would be appreciated
  2. Feb 16, 2018 at 11:52 AM
    81shark
    81shark Well-Known Member
  3. Feb 16, 2018 at 11:55 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It may be stuck on the alignment dowels. Visually make sure all the wiring is disconnected and then start yanking..
