09 OR DCSB 206K FULL SERVICE ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MoTacoX, Nov 30, 2023.
  1. Nov 30, 2023 at 4:36 AM
    MoTacoX
    MoTacoX [OP] Well-Known Member
    Just got back my 09 OR from loaning it to my company. It's time to show it some respect. At 206k is it time for timing chain/water pump? All fluids of course...what else?
    Thanks!
  2. Nov 30, 2023 at 10:50 AM
    RockfordTaco2006
    RockfordTaco2006 Well-Known Member
    Alexander
    2006 Toyota Tacoma TRD Off Road 4x4
    2 Inch Lift
    Spark Plugs
    Belt
    PCV Valve
    Rubber Hoses
    Good Luck!
  3. Nov 30, 2023 at 11:06 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Did your work maintain it? See what they did. At 200K it would need coolant flushed. At that mileage, as preventive maintenance, I replaced cooling components - radiator, fan clutch, fan, water pump, thermostat. Water pump shaft had some play, so, glad I replaced.
    Hoses/belt were replaced at 100K and looked good, so didn't replace them. I would replace if over 150K.
    Good time to check your idler/tensioner pulley bearings for play.
    Check brake pad wear; check wheel bearing play.
    Check u-joint and center bearing for play. Maybe replace as preventive maintenance if more than 100K on them.
    ATF flush if at 60K - using Toyota severe service recommendation.
  4. Nov 30, 2023 at 12:01 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    i changed my air filter and plugs around 200k along with new UCA, LCA, shocks n struts, steering rack and steering shaft.
    Other than brakes and a light here n there, not much has failed in 300k except my frame rotted out
