09 Parking Light Trouble
Discussion in 'Lighting' started by BRUIN8124, Jul 6, 2012.
  1. Jul 6, 2012 at 10:36 PM
    BRUIN8124
    BRUIN8124 [OP] Well-Known Member
    Mark
    2020 TRD 4X4 OFF ROAD DCSB
    Looking for some advice...
    I noticed that my 09 passenger side front parking light was out a few weeks ago. I purchased a new bulb and went to switch it out. When I checked out the old bulb, it looked ok. I plugged it back in and it still worked when I turned the lights on.
    A week or so later, the light was out again. I got it to go back on by just tapping on the headlight assembly. Then it was fine for a while.
    That was happening more and more so I put the new bulb in anyways. It is still happening.
    Thoughts? Loose wire maybe? As far as I can tell, it looks ok.
    I dont know, it is kind of annoying. Anyone else had this problem? All other bulbs and fuses are ok. I would rather not take it in to the shop for something like this.
  2. Jul 8, 2012 at 8:00 PM
    BRUIN8124
    Mark
    (bump) Anyone?
  3. Jul 8, 2012 at 8:12 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Connection in the harness. Possibly where the harness plugs into the bulb socket.
    It can be a bit of a pain to separate, but get it apart (take your time) and put some tune-up grease on the pins.
  4. Jul 9, 2012 at 11:42 PM
    BRUIN8124
    Mark
    Thanks Rich!
    That seemed to do the trick. So far, so good anyways...
    +1
