09 Rear Lockers-Necessary?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by a.carter251, Jan 3, 2010.
  1. Jan 3, 2010 at 2:12 PM
    a.carter251
    a.carter251 [OP] Member
    Alex
    I am looking at 09 double cabs and the packages that come with them. My friends always talk about "lockers" when they go wheelin, i am thinking about getting 4x4, should i spend the extra money to get them, or should i just say forget it?
  2. Jan 3, 2010 at 2:53 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    If you're gunna wheel, the locker can be an invaluable asset. Otherwise, it's completely useless on the street
    Also, TRD Off-Road is the only package that has the e-locker. You can always add an aftermarket later (at considerable cost).
  3. Jan 3, 2010 at 3:22 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    4x4 is nice if you wheel or live in an area that warrants it. The locker is always nice to have.
  4. Jan 3, 2010 at 3:28 PM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    I agree - I have only used mine once, and that was only to make sure it still worked.
  5. Jan 3, 2010 at 3:31 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Get the locker if you do any sort of 4wheeling. I use mine all the time and it works like a champ. But if 4 wheeling to you is driving down a dirt road and minor rock and mud stuff then you may want to save your money. To me it is priceless.
  6. Jan 3, 2010 at 4:18 PM
    tussery
    tussery Well-Known Member
    Corpus Christi, Tx
    09 PreRunner SR5
    Magnaflow muffler, TRD CAI.
    Meh... lockers are over-rated for off-road use. Full spools are the real answer...
  7. Jan 3, 2010 at 4:24 PM
    09tacoLI
    09tacoLI Well-Known Member
    long island ny
    09 off road
    Shrockworks sliders,Shrockworks Front bumper,Warn 9.5xp winch,Toytec Ult.3in,Total Chaos UCAs,AP expo Rear, Fox remote resi shocks Bud built skids,Piaa 7in,Piaa yellow plasma Off road lights.
    I like having another tool to use if you wheel your truck its a great tool.
  8. Jan 3, 2010 at 5:08 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I have found the rear locker to be essential for when I get stuck while in 4LO. That is to say I am in four wheel drive low and I get stuck. That's when I have found it to be invaluable. It has always got me out. Sometimes if there is an extreme rough patch going uphill or down I'll engage the locker to get me through and then I unlock when I am out of the rough spot.
    I use it exactly as the Toyota manual says to use it. I have used it two dozen times in the last 6 months on trails in California and Nevada.
    A-TRAC is nice too. I leave that switch enabled all the time. A-TRAC only works while going less than 3 mph and in 4LO. With A-TRAC enabled and the rear diff locked the Tacoma is a beast!
  9. Jan 3, 2010 at 6:24 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    for heavy off-road yes, otherwise no
  10. Jan 3, 2010 at 6:27 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    when my locker engages it is basically a spool.
    a spool just locks the axles so they both accept the power from the dif....right?
    But to the op: it really depends on your needs. i use mine quite often. but i also wheel my truck almost every weekend and i wheel it pretty hard. so yes it works for me and it was worth it.
  11. Jan 3, 2010 at 7:59 PM
    a.carter251
    Alex
    thanks! im thinking about just going and getting it just incase i need it in the futre
  12. Jan 5, 2010 at 3:05 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Got my 2010 Tacoma last month... 4WD DC TRD Off Road.
    Just was in Baja for New Years and really put the new system to a test. TRAC in H4 is awesome... no need to deflate tires for deep sand. In deep arroyo sand/ gravel, TRAC pulled us through with no issues what so ever. I dis-engaged TRAC while on the beach and the truck soon bogged down. I engaged L4, A-TRAC and the Rear Diff.Lock and the truck pulled itself out from being stuck!
    Incredible... it works... 4WD with TRAC (in H4) or A-TRAC (in L4) is all four wheels working and non spinning useless or digging you into the sand as with standard open differentials (as was my 2005 Tacoma. The RR locker was engaged for max. power to both rear tires to get un-stuck.
  13. Jan 5, 2010 at 5:03 PM
    rhodehard09
    tampa, fl
    nice post!
  14. Jan 5, 2010 at 5:51 PM
    BBQ BOY
    BBQ BOY Well-Known Member
    Yea but how about people like me who love the look of the Sport? I still haven't bought a Tacoma and this is my biggest dilema. The truck will see 80% on road but I will use it for hunting and trail riding with my Land Cruiser club. I REALLY LOVE the look of the Sport.
  15. Jan 5, 2010 at 5:55 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    I like the color matched panels... minus the fake hood scoop. My truck has color matched grill and rear bumper now. Being BSP, the black plastics dont' bother me they're not BSP. :shrug:
  16. Jan 5, 2010 at 5:58 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    you can get an aftermarket replacement trd sport hood for 300 and a aftermarket replacement grill surround for 180 iirc and rear bumper then just have them painted...
  17. Jan 5, 2010 at 6:19 PM
    BBQ BOY
    Ok. So what are the cost for aftermarket lockers?
  18. Jan 5, 2010 at 6:26 PM
    westport toyota
    westport toyota Active Member
  19. Jan 5, 2010 at 7:08 PM
    David K
    The fake hood scoop interfers with driver visibility, when doing serious off roading... Get the off road TRD! A-TRAC in Lo4 is more important than the scoop...
  20. Jan 5, 2010 at 7:21 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Yeah as long as you are slippin in sand otherwise they could get you in trouble too - I use mine all the time. I wouldn't have an off road truck with out one (budget dependent).
    Regarding 'selectable' lockers that allows the driver to desicide when it locks and when it doesn't you are looking at the Toyota (Eaton) eLocker or ARB selectable air locker. Prices range depending upon who is installing it and if you care to regear at the same time.
    ARB Locker itself is in the $700-$1000 range
    compressor 200-300
    Setup of rear 150-250
    Install 150-400
    Somewhere around there.
