09 rwd Tacoma brake line replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dziadzu, Jul 13, 2020.
  1. Jul 13, 2020 at 4:53 PM
    Dziadzu
    Dziadzu [OP] New Member
    2009 2wd Tacoma
    none
    The steel brake line that travels (I think) from engine compartment to the rear of my truck have rusted open. What will a Toyota service dept. have to do to replace them? Will the bed and the cab have to be lifted?
  2. Jul 13, 2020 at 5:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I haven’t looked hard, but I believe they run down the side of the frame.
    I don’t thinking either would have to be removed.
    If I ever have to do it, I’d probably use Copper/Nickel Line and do it myself.
    @jboudreaux1965 may know more about it?
  3. Jul 14, 2020 at 5:57 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    The brake lines run inside the driver's side frame rail. From what I remember, they just snap into holders attached to the frame rail.
  4. Jul 14, 2020 at 7:49 AM
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    El Paso, Texas
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    That is correct, I just did this.
    They do run along the driver's frame rail. My clips almost all broke when I removed it due to brittleness. There is a connection/transfer block just under the driver's door area.
    Here
    The lines on the right come from the engine bay, the ones on the left go back to the rear axle.
    I did not route the line back in the same way though, I could not get it past the fuel tank and I did not want to drop the tank. I used a pre-bent OEM line from Toyota.
    If you used copper alloy or any line you bend yourself you should be able to get it back closer to the original routing.
    TnShooter likes this.
  5. Jul 14, 2020 at 8:26 AM
    Dziadzu
    2009 2wd Tacoma
    none
    I really appreciate your responses. Thanks.
    ohcaltexscar likes this.
  6. May 24, 2022 at 2:24 PM
    michael2468
    michael2468 Active Member
    North Adams, Ma
    2009 Tacoma SR5 Package
    Ohcaltexscar,
    Could you explain how you made repair using oem pre bent line from toyota . how did you rought the line. I have ordered this line and waiting for it to come in actually ther is two lines and I need to replace both. Any help you can give me would be greatly appreciated.
  7. May 25, 2022 at 4:27 AM
    ohcaltexscar
    Chas
    El Paso, Texas
    I was not able to route it back through in the OEM location, those two lines run back along the inside of the frame rail and go in between the frame and fuel tank.
    When I removed the old one I had to cut it in a couple of places to get it all out.
    I tried for quite a while to jockey both the old line, (to remove) and the new line, (to install) around and fit it back through there but with the way that it’s pre-bent it just would not work.
    I ended up just routing it back over the fuel tank and spun it around until it sort of “settled” into a comfortable spot. Once I was able to make both connections I used zip ties to secure it in a few spots.
    I would go take a few pictures but my truck is in the shop right now, if I get it back before you get to your line install I’ll get some posted up here.
  8. May 25, 2022 at 5:16 AM
    michael2468
    North Adams, Ma
    Which direction did you start from, front to rear or rear to front. Thanks again for your help
  9. May 25, 2022 at 6:01 AM
    ohcaltexscar
    Chas
    El Paso, Texas
    I fed it over the tank from front to rear. I made the rear connection first and then connected to that front block. I did have to bend the line a little bit on the ends to line up connections. You may or may not have to depending on how yours sits.
    The rear connection is right past the end of the fuel tank so it doesn’t need to go far.
    Lumberjackcoma likes this.
