09 SRS Sensor/DTC Help Needed
Discussion in 'Technical Chat' started by brutalguyracing, Jan 16, 2013.
  1. Jan 16, 2013 at 8:58 PM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    yaw rate sensor is bad went under water
    is this a direct replacement or does new one have to be programmed by a dealership?
    any advice is appreciated
    09 tacoma
    part # is toyo 89183-60020
    denso part # 174500-5431
    12v
    thanks
  2. Jan 16, 2013 at 9:14 PM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    It can be cleared and calibrated using a jumper wire. You need to find a service manual and look under brake control: vehicle stability control calibration. Or find someone that has posted zero point calibration after lift and alignment
  3. Jan 16, 2013 at 9:21 PM
    Ryanv
    15 4Runner
  4. Jan 17, 2013 at 5:15 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    thanks ryan
  5. Jan 17, 2013 at 12:36 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    ok so i did the jumper wire blink test
    and i came up with 5 trouble codes
    1st-----31 = Center Airbag Sensor Assembly Malfunction
    which i assume is just caused by the other trouble codes being thrown "correct?"
    http://share.qclt.com/丰田Toyota RAV4...tal Restraint System/Airbag System/043006.pdf
    2nd--------35 = Seat Position Airbag Sensor Circuit Malfunction
    no idea where or what this is ?:mad:
    http://share.qclt.com/丰田Toyota RAV4...al Restraint System/Airbag System/0430021.pdf
    3rd ---------37 = Driver Side Seat Belt Buckle Switch Circuit Malfunction
    looking into this:mad:
    http://www.customtacos.com/tech/files/05FSM/data/ileaf/06toyrm/06toypdf/06rmsrc/rm2006ta/0470012.pdf
    4th --------55 = DTC B1820/55 Short in Driver Side - Side Squib Circuit
    DTC B1821/55 Open in Driver Side - Side Squib Circuit
    DTC B1822/55 Short to GND in Driver Side - Side Squib Circuit
    DTC B1823/55 Short to B+ in Driver Side - Side Squib Circuit
    unsure what this is wiring maybe???:cool:
    http://www.purefjcruiser.com/docs/2...al Restraint System/Airbag System/0340031.pdf
    5th -------56 = DTC B1825/56 SHORT IN SIDE SQUIB (P SEAT SIDE)
    CIRCUIT
    DTC B1826/56 OPEN IN SIDE SQUIB (P SEAT SIDE)
    CIRCUIT
    DTC B1827/56 SHORT IN SIDE SQUIB (P SEAT SIDE)
    CIRCUIT (TO GROUND)
    DTC B1828/56 SHORT IN SIDE SQUIB (P SEAT SIDE)
    CIRCUIT (TO B+)
    unsure of ?:mad:
    http://tijil.org/Scion_Docs/05_tC_S...cs/Supplemental Restraint System/cib18255.pdf
    mind you truck was under a few inches of salt water.....in cab:eek:
  6. Jan 17, 2013 at 12:42 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    ^^ in red
  7. Jan 17, 2013 at 12:44 PM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Occupant detection computer, under passenger seat. Said that the day she went under...just sayin.
    Hope you get this squared away. I would wager this takes care of a few of your codes.
  8. Jan 17, 2013 at 12:53 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    I dont see no sensor under pass seat....on the floor
    Guess I will pull seats and check
    I thought for sure it was the yaw rate sensor as I vacumed it out of a puddle
  9. Jan 17, 2013 at 12:59 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    Dont think it has anything to do with the spiral cable as this happened the day it went under
  10. Jan 17, 2013 at 1:21 PM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Its a black box maybe 3"X4"x1/2" thick mounted to the under side of the seat. Mine was toast after I went under. Fixed everything when I changed it.
  11. Jan 17, 2013 at 4:09 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    dont think the water got up that high
    also was it plug n play or did it have to be reprogrammed or something
  12. Jan 17, 2013 at 4:35 PM
    Ryanv
    15 4Runner
    Can you get the actual codes from the vehicle with a scan tool?
  13. Jan 17, 2013 at 4:44 PM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    I think Scott tried that but couldn't get anything.
  14. Jan 17, 2013 at 4:50 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    dont have a scan tool but did the jumper wire / blink test and came up with codes
    31
    35
    37
    55
    56
    which from what i have been reading looks like floor wire #2 and maybe inner belt sensor.....
  15. Jan 17, 2013 at 4:53 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    and i am thinking my yaw rate sensor is a complete separate issue?
    need to find a way to test it
    i know it has a problem when it detects wheel slip
  16. Jan 17, 2013 at 4:53 PM
    Ryanv
    15 4Runner
    give me 5 min to look into this.
  17. Jan 17, 2013 at 5:02 PM
    Ryanv
    15 4Runner
    From the codes you have provided with out a scan tool to get actual codes, and without actualy touching the truck it looks like it will be your center airbag sensor assy. Going through the diag trouble code flow chart the only thing that all those codes have in common is the airbag ecu under your center console. I would start with that it is plug and go.
    For the yaw rate sensor try to clear the calibration and recalibrate before changing it.
  18. Jan 17, 2013 at 5:12 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    thanks for all the help
    its just that i know the air bag ecu did not go under the water.....
    but i think i am going to get one anyway.....
    tomm i might pull the seats and console and investigate further....
  19. Jan 17, 2013 at 5:45 PM
    Ryanv
    15 4Runner
    None of the codes relate to this ecu. if IGN 15A and IG1 10A fuse are ok it points to center airbag sensor
  20. Jan 17, 2013 at 6:13 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
