09 SRS Sensor/DTC Help Needed
Discussion in 'Technical Chat' started by brutalguyracing, Jan 16, 2013.
  1. May 1, 2013 at 6:51 AM
    #61
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    Ok got that
    Now just looking for how to test just the sensor
  2. May 1, 2013 at 7:25 AM
    #62
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Toytec (Eibach) coils with bilstein 5100 shocks and Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Wheelers Super Bumps,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    :popcorn: Any luck?
    I am not positive but if you could get somebody withe a computer they should be able to test that for you.
  3. May 1, 2013 at 7:34 AM
    #63
    brutalguyracing
    F.U> GUYZ
    broken mods
    No not yet been standing online for an hour so far to get my 2 nd beach permit
    Got to have priorities
    But i had a guy nj636 try his computer
    And it said it could not communicate with my truck
    But yet i can use the paperclip method and pull all the codes
    What i have figured out is all 5 have the control module as the common denominator
    So for $47 im going for it
    But would like to know if sensors are bad as the 2 side airbag sensors were under
    But they are sealed nice
    All conectors are beautiful
    So who knows
  4. May 1, 2013 at 5:48 PM
    #64
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    DO NOT test resistance in the srs system that is connected to a squib or airbag that is what will set air bags off. Ohms are basically tested by sending a voltage from your meter and reading what comes back.
  5. May 1, 2013 at 6:11 PM
    #65
    brutalguyracing
    F.U> GUYZ
    broken mods
    I was going to check all systems as the references in my first post
    As per fsm
    I sent out the center module to get checked / reset
    It didnt not take on any water
  6. May 4, 2013 at 9:08 PM
    #66
    brutalguyracing
    F.U> GUYZ
    broken mods
    Hey ryan
    I just sent out the center srs module to be cleared or reset
    They just informed me its all good to go
    And should be here monday
    Should i just plug it in n see what happens
    Or should i test each squib and such as per fsm
    As to not throw another code
    I have inspected all wiring n such
    I see nothing as in major components that got wet as in belt tensioners and such
    Thanks
  7. May 5, 2013 at 9:29 AM
    #67
    Ryanv
    15 4Runner
    If you have check all wires that are related to the codes you have and are all in spec all you can do is plug it in and hope for the best. Do all the female pins look tight free from corrosion? Is this a new or know good center sensor? There is no way to safely test squibs the FSM recommends borrowing know good parts for diag.
  8. May 5, 2013 at 2:30 PM
    #68
    brutalguyracing
    F.U> GUYZ
    broken mods
    No signs of any corrosion anyplace
    Same center module just had it reset or cleared and checked out by air bag company
    Guess i will find out soon
    Thanks for all your help
    Rep your way when i get home
  9. May 6, 2013 at 5:56 PM
    #69
    brutalguyracing
    F.U> GUYZ
    broken mods
    update
    thanks ryan for all your help you have been great
    i re installed the srs module after i got it back from myairbags.com $47 with shipping had it back in 3 days
    light is off and i believe all is well......
    i also installed a new yaw rate sensor.....
    which i need to calibrate using the zero point calibration method....with jumper wire
    as soon as i can find a level area.....
  10. May 6, 2013 at 8:00 PM
    #70
    Ryanv
    15 4Runner
    Glad you finally got it sorted out
  11. May 6, 2013 at 9:25 PM
    #71
    brutalguyracing
    F.U> GUYZ
    broken mods
    Woot me too
    Should have done that first
  12. Nov 7, 2013 at 6:49 PM
    #72
    brutalguyracing
    F.U> GUYZ
    broken mods
    UPDATE
    EVERYTHING IS STILL A OK
    THANKS AGAIN RYAN......
