09 taco lifted too much in the rear? dealer smart or not?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zero niner, Mar 17, 2009.
  1. Mar 17, 2009 at 4:20 PM
    zero niner
    zero niner [OP] romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    Hello,
    So I take my Prerunner to get the TSB done today, it had when it went in, Billy's up front set at 1.75" and a 1" lift block in the rear, I just got the call that they put in the rear leafs and shocks AND left in the blocks ("because it's better"), now I'm no rocket scientist but won't my angle be too much??? :eek: The rear has got to have 2.25" lift now right? I put on 265/75R16 Revo's yesterday to take advantage of the free alignment.
    I'm still at work and haven't seen the truck yet but wanted to see if anyone had an opinion about what I should expect to see and if I shouild get the rear blocks removed (yes, the same blocks I just put up for sale) :rolleyes:
    And the most important question is, why don't they call me BEFORE they do work against my work order??? :confused: Crazy dealers!!!
    Venting...
    Rob
    Dr. Jekyll likes this.
  2. Mar 17, 2009 at 4:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I would have had them not install the blocks. Part of the TSB is also new U bolts, which Im sure they didnt install if they put the blocks back. Seems every time I hear of a TSB, the dealer is not wanting to install the new U bolts....
  3. Mar 17, 2009 at 4:29 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    well you could just bump the billis up to 2.5 and it should level it out some. But you will still be alittle higher in the back. Do you tow a lot of carry loads in the back? If so it might help having it alittle higher in the back... just my .02
  4. Mar 17, 2009 at 4:31 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    I wonder why that is, they went through the trouble of changing out the leafs so the U bolts had to come off, why would they not change the U bolts. I may just have them lift the front to 2.5" since they're messing up my work order, this is not the first time I've had problems at my dealer. Of course I wouldn't expect to pay for it...
    Rob
  5. Mar 17, 2009 at 4:34 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    I'm a part time handy man so loads happen maybe once a week or so, I do have my UWS with tools loaded in them constantly, but I can't believe they drove the truck out of the shop and said, now that's a great looking truck, nothing like having the rear WAY high, cause that's what I'm imagining when I go to pick it up... :mad:
    Rob
  6. Mar 17, 2009 at 4:35 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Thanks for the feedback, what lift do you have up front? How long did it take to settle?
    Rob
  7. Mar 17, 2009 at 4:36 PM
    rmb_crew
    I dont think it will be as high as you think. I got mine done and at first i could tell it was higher in the back and than once it settled out i thinks its only an inch to an inch and a half higher than the front. Now thats stock. so the spacer shouldnt be too bad.
  8. Mar 17, 2009 at 4:56 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Did you discuss with them to take the blocks OUT after the old springs were out and the new TSB springs were put in? If you did, you didn't mention that part.
    My bet is that you'd have a post here bitching that it was too LOW after the TSB because the DIDN'T put the blocks back in IF they did take them out.
    (You don't have to remove the U-bolts to swing the spring. Loosen the nuts, drop the plate and use that to support the weight of the spring. Lift the spring, flipit ,slide it to the back and slide the new ones in....invrt once again.....Sounds about right)
  9. Mar 17, 2009 at 5:11 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
  10. Mar 17, 2009 at 5:31 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Thanks for the info, your truck is badass! Checked out your build, great job!
    Rob
  11. Mar 17, 2009 at 8:14 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    I picked it up tonight, and I don't really care for the look, the rear is a full 2" higher than the front
    Ground to bottom of flare in front 36.5" and rear 38.5"
    I really like the stiffer feel of the truck but will probably have them remove the 1" blocks as I don't believe it's going to settle over an inch. I'll post pics when the daylight comes around again.
    Rob
  12. Mar 17, 2009 at 9:23 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    I would hold off just a bit...
    I bet the rear will settle at least an inch...
    If not, then you can take the block out...
  13. Mar 18, 2009 at 1:11 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I Have a 3" spacer lift on the front of my truck(dropped slightly due to bumper weight, probably 2.5" lift actually) and the TSB with 1" block under the back and it sits even by wheel well clearance, but the bed rails visually angle down. I'm getting a 1.5" AAL and installing it within the week to get the back to where it was before the TSB(had a 2" aal in my old pack). When I changed over my winter tires back to my regular tires/wheels I stuck the jack under the back and lifted it until I thought the stance was proper, turned out I liked it exactly 1.5" higher than regular ride height.
  14. Mar 19, 2009 at 9:17 AM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    pics are always fun!
  15. Mar 19, 2009 at 9:48 AM
    Munkey
    Munkey Well-Known Member
    Paducah, KY
    2008 Radiant Red 4X4 Double Cab Sport
    OEM Tube Steps, Bed Extender, Pioneer Avic D3 with Bluetooth and XM Radio modules
    I don't think that's a fair measurement. The bottom of the flares may not be the same distance from the ground even when the cab is exactly level. Looks fine to me in the pics.
  16. Mar 19, 2009 at 9:53 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Just my opinion, but I think it looks good as is. I'd leave it.
  17. Mar 19, 2009 at 10:23 AM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Yes it is 1" block and TSB springs, and I also voted that you get the All Pro bumper, I posted an instruction/installation thread and there's good info about getting the fitment right too. Thanks again for your feedback.
    Rob
  18. Mar 19, 2009 at 10:24 AM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    I completely agree but it works well for before and after measurements and some sort of consistent personal reference point, I'd say that they'll only work for your truck due to the spec differences that you mention. Thanks!
    Rob
  19. Mar 19, 2009 at 10:27 AM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    HA! I just figured out how to multi quote responses. Yeah! I guess it doesn't look so bad after all and since everyone says it will settle, then I'll wait to see what it looks like in a few months. Thanks again for everyone's responses and advice. I really apprecaite them!
    Rob
  20. Mar 19, 2009 at 7:27 PM
    Dr. Jekyll
    Dr. Jekyll Well-Known Member
    Jimmy
    Honolulu, HI
    2015 Black DCSB Limited PreRunner
    I agree. You have to measure either the side steps or the body crease in the doors to get a sense of the level. It does however look like a good stance from your pictures.
