09 Tacoma - 2.7L Oil Filter Part #
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mna89, Jul 26, 2009.
  1. Jul 26, 2009 at 12:24 PM
    mna89
    mna89 [OP] New Member
    I've tried searching the web and various forums but I'm still confused on the correct part number for the oil filter for the '09 2.7L Tacoma engine.
    An online parts retailer suggests 90915-YZZD1 but other sources specify 90915-YZZG1. Which one is correct? Thanks!
  2. Jul 26, 2009 at 1:24 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I don't have the answer, but it should be the same as a 2008, no change on the taco mechanically from what i hear.
  3. Jul 26, 2009 at 4:52 PM
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    When I went to the dealer to get my first filter they gave me the V6 filter (90915-YZZD3) instead of the I4 filter. Well it fits and I think it is a better choice since it is bigger. There is also some confusion on how much oil the I4 requires for an oil change. 6.1 quarts will show a big overfill on the stick. So I use 5.75 quarts with the V6 filter which will still show an overfill on the stick but nothing ridiculous.
  4. Jul 26, 2009 at 6:48 PM
    mcgiiver
    mcgiiver Well-Known Member
    Princeton, NJ
    2009 Access cab 4x4, 4 cyl, stick
    Aftermarket Driving Lights, Hidden Hitch, Removed rear headrests, Side protective moldings, vacuum gauge, Scan Gauge, Leer cap.
    The OEM dipstick is so bad , I can't even tell where my oil level is. Maybe as the oil gets dirtier it will be better.
  5. Jul 26, 2009 at 6:51 PM
    mcgiiver
    Princeton, NJ
    Fram PH 3614 for the I4 engine
  6. Jul 26, 2009 at 6:52 PM
    Tacoyota
    08 4wd
    I put 6qt in not the 6.1qt, same cant read a vague toyota dipstick thing.I'm sweating that 1.6 ounces...not really
  7. Jul 26, 2009 at 9:18 PM
    CometKat
    Carson City NV
    If you scuff up the stick you can get one good reading after the truck has been sitting overnight
  8. May 22, 2014 at 3:33 PM
    DealerDoesNotKnow
    DealerDoesNotKnow New Member
    Texas
    4cyl 2.7
    CometKat,
    I have attempted to explain this issue to more service managers, including the dealership's...they nod their heads and set the autofill at 6.1, and my dipstick reads 1/2 inch too high, just like I told them it would when I arrived. I have never been able to resolve whether the problem is with the specifications or the dipstick. Should I try calling the manufacturer?
    Since going to the dealer for my last oil change didn't help, my husband has finally agreed to do it himself. He's a carpenter and doesn't like mechanic work, but HE's the one who blows a gasket if they don't do it right. I am now about to go to purchase all the supplies, and that is why I find myself researching all day on sites like this one. Socket wrench, torque wrench, filter wrench, 5W20, crush washer, ...
  9. May 22, 2014 at 8:04 PM
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
  10. May 23, 2014 at 5:36 AM
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    I noticed that on my Scion and my Tacoma, the factory oil filter that I removed didn't have the same part number as the whole case of filters that I bought from the dealer. The factory filters are Japanese while the dealer has ones made in Taiwan. My truck takes exactly six quarts. Right to the top of the full line. It sucks because I can always find a deal on a five quart jug...Then have to spend a ton on one extra bottle. I use a 14mm box end wrench to remove and install the drain bolt. Trust me when I say that the monkeys changing oil at the dealer aren't torqueing anything.
  11. May 23, 2014 at 5:36 AM
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    They are both correct. I think that the only difference is the country of manufacture. I wouldn't use the V-6 filter because of different spring rates in the bypass valve. It may be O.K. I'm just not sure. Also, at 21,000 miles, I use synthetic 5w-30 here in Florida.
