09 tacoma, 4wd, MT thumping when shifting gears
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yourassf4ce, May 25, 2025.
  1. May 25, 2025 at 1:51 PM
    yourassf4ce
    yourassf4ce [OP] Member
    Hey everyone! I'm having trouble diagnosing a thumping sound when I shift gears. I drive an 09 base tacoma with 1GR-FE (4.0L V6) engine, 4wd, manual transmission. Over the past few months, when I shift from 1st to 2nd, 2nd to 3rd gear, and less so with the higher gears, I get a loud thumping sound that appears to be coming from the rear end. I thought it might be an aftermarket hanger bearing I installed, but I've shot videos under the truck while shifting, and the hanger bearing looks okay. The engine block doesn't seem to move too much either. It appears to be the rear axle that is moving the most, but to be frank, I don't know what normal looks like. I wanted to see if anyone had some insight as to what this might be. I posted the video of the rear differential and axle on youtube:
    https://youtu.be/VhLdaKKqI0M
    Thanks for y'all's help.
  2. May 25, 2025 at 2:40 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I've never looked at mine like that but based on your video, the first thing I would look for is a busted leaf spring. It looks like that rear diff is rotating more than I would expect.
    spitdog and GilbertOz like this.
  3. May 25, 2025 at 3:11 PM
    Clearwater Bill
    Billy
    Largo Florida
    Unsure of the problem, but it is a great video!
    I would be suspect of the spring area as well.
    Loose u bolts? Have the springs been touched? Blocks? Add a leaf? Warranty replacement springs?
    winkel likes this.
  4. May 25, 2025 at 5:05 PM
    yourassf4ce
    Ok, that makes sense. That's what I was thinking.
    I'll take a look at the u bolts. I bought the truck with 164k and it's up to 209k. I think it's been lifted by the previous owner, but I haven't modified the suspension. I'll look at the warranty too. I remember seeing that.
  5. May 27, 2025 at 12:20 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I watched the video at .25% speed and between the 19 second mark and the 23 second mark it appears that the pinion gear shaft jumps like a tooth.
    Slow it down and watch it. Maybe I'm old and crazy, but it looks that way to me.
    winkel likes this.
  6. May 27, 2025 at 12:32 PM
    Clearwater Bill
    Billy
    Largo Florida
    Yea. Maybe. :rofl:
    Doesn't mean you don't know what you're doing though. :thumbsup:
    winkel and Jimmyh[QUOTED] like this.
  7. May 27, 2025 at 5:53 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    U-joints?
  8. May 27, 2025 at 7:16 PM
    winkel
    Corydon, IN
    Lol, that's pretty much the same thought I had.
    Jimmyh likes this.
  9. May 28, 2025 at 9:07 AM
    yourassf4ce
    That's definitely when the thump is happening. Does that mean the diff needs rebuild if that's the case?
  10. May 29, 2025 at 7:07 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    You would have to dig into it to find out. IMO there is something def going on. It shouldn't do that...
    I would remove the drive shaft and inspect those universal joints also!
    Put the rear end up on jack stands and rotate the pinion while the shaft is out and see what you feel when rotating the differential by hand. That may help you isolate the problem.
    winkel likes this.
  11. May 29, 2025 at 12:01 PM
    yourassf4ce
    Ok. I'm going to check it out this weekend.
  12. May 29, 2025 at 12:52 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Please update the thread when you find anything.
    Thanks!
    winkel likes this.
  13. May 29, 2025 at 6:12 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I don't know much about differentials but it seems to have a ton of backlash (in the gears?... comparing how much the drive shaft rotates before the tires start to move) compared to what I would expect to see, but then again I never see mine in action to know if it is any different.
  14. May 29, 2025 at 8:43 PM
    yourassf4ce
    Yeah that's what I'm thinking. I'm hoping it's just the pinion nut that came loose and I can tighten it back up.
  15. May 30, 2025 at 7:44 AM
    NC06TACO
    NC06TACO Member
    2012 Tacoma AC 4x4 OR - 6spd
    Really good video. I am experiencing something similar and trying to figure it out. Following!!!
  16. May 30, 2025 at 11:28 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Before you go messing with the u-joints you should check the torque on the U-Bolts holding the springs. I had a similar issue on my truck years ago and that's what it turned out to be. I think the proper torque spec is 73 ft/lbs but the service manual had it misprinted at 37 ft/lbs. It's worth a shot plus it's easy and free.
    Jimmyh likes this.
  17. May 30, 2025 at 11:30 AM
    yourassf4ce
    That's a good idea. I'll check it out.
