09 Tacoma Helper Springs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Pastor, May 2, 2022.
  1. May 2, 2022 at 8:02 PM
    Taco Pastor
    Taco Pastor [OP] Well-Known Member
    Brian
    2009 Tacoma V6 access cab 6spd Barcelona rec
    https://www.amazon.com/SUPERIOR-11-1040-Super-Leaf-SPRING-2000LB/dp/B00029K1X0
    https://www.ebay.com/itm/233966570249?epid=1111817143&fits=Submodel%3ABase%7CYear%3A2009%7CEngine+-+Liter_Display%3A4.0L%7CModel%3ATacoma%7CMake%3AToyota%7CTrim%3ABase+Extended+Cab+Pickup+4-Door%7CEngine%3A4.0L+3956CC+241Cu.+In.+V6+GAS+DOHC+Naturally+Aspirated
    Can some one please look @ these two and tell me IF they will hurt my lift height in the rear and possibly hurt my carrier bearing? I may need to tow this summer and want to avoid rear squat that might affect my performance.
    So I have to travel 500+ miles and then 500+ back, but if they will affect my lift it will be before I tow right, but then level out(not hurting the carrier bearing)?
    Thanks,
    Brian
  2. May 3, 2022 at 8:21 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
  3. May 3, 2022 at 8:25 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If you are looking into helper springs to help you in towing, know that the helper is not going to doing you any favors. Do it right and either get a AAL that is built around our current 3/4 leaf setups, or get full new leaf pack setups that are designed for towing in mind.
    Adding a helper to an already weak, inadequate amount of leaf springs setup from factory configuration will not do anything for you.
    6 gearT444E likes this.
  4. May 3, 2022 at 8:30 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    that is true, if the pack is stock and shot, nothing short of a new pack will fix it.
    12TRDTacoma[QUOTED] likes this.
  5. May 3, 2022 at 12:58 PM
    Taco Pastor
    Brian
    My springs are TSB as of June 2020 and my shocks are new 2020 as well
  6. May 3, 2022 at 1:05 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I'm a fan of air bags since most of the time I carry about 200 lbs, but that jumps up to 600+ when I load gear for camping. I can quickly adjust back and forth, and they just work alongside your existing leaf springs.
