09 Tacoma Sport Squeaking noise while in gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brandbless, Apr 22, 2022.
  1. Apr 22, 2022 at 6:44 PM
    brandbless
    brandbless [OP] Member
    Brad
    2009 Toyota Tacoma TRD Sport
    I have a 2009 Tacoma sport Manual, When in gear on the gas i have a loud squeaking and occasional loud tapping noise happening while accelerating. When rolling in neutral sound is not there. It’s getting very loud And is starting to Tap more often, Scary noise for me.. Wondering what the issue could be if anyone can help?
  2. Apr 22, 2022 at 7:37 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Possible ujoints- but under load it shows and with no load on drive train no there
    How do they look? Center bearing? Only should have just a little bit of play
  3. Apr 24, 2022 at 10:33 PM
    brandbless
    Brad
    Greased U Joints and Most sound stopped, however i wasn’t able to grease the rear zerk fitting It just wouldn’t take any grease, and i still have a squeak when in reverse. Yes only squeaks under load Drive train looks good has only a little play
  4. Apr 25, 2022 at 3:03 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    U-joints as mentioned. You need to pull the drive shaft ends and move the joint around to check properly. The rear one you couldn't grease is probably going to be very stiff or one of the crosses leaking rust dust.
    BassAckwards likes this.
  5. Apr 25, 2022 at 6:09 PM
    802FB
    802FB Member
    I'm having what sounds to be the same issue, but I have a nearly new Tom Woods single piece drive shaft that I installed 8 months ago. I reached out to them and they said it could be the double cardan.
