09 Tacoma stalling 12 engine codes!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cory, Apr 2, 2015.
  1. Apr 2, 2015 at 11:26 AM
    Cory
    Cory [OP] Member
    09 Tacoma TRD Sport
    Hey all,
    My 09 taco has left me stranded twice now, check engine light appears along with the tcs light, it will run real rough for about a km and then it will shut off, it will start back up long enough to shut back off again, 12 engine codes come up, 2 codes for each coil pack show up, if the truck sits for about an hour the codes will clear and the truck will start and run perfect until the next time... Truck is an 09 trd sport 4.0l auto, both times it died the temp was above freezing after being extremely cold in the morning and also after driving approx. 1.5 hours.
    I'm really hoping someone has some insight, my dealership up here in NS has never had this issue.
    Thanks, Cory
  2. Apr 2, 2015 at 12:50 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    possible frozen stuff finally heating up and evaporating up into a connector or something causing a short.
    What 12 codes come up?
  3. Apr 2, 2015 at 1:02 PM
    Cory
    Cory [OP] Member
    09 Tacoma TRD Sport
    130km
    Spark plugs were never changed by me and I've had it since 60km
    It throws 2 codes per each ignition coil like p0351, p0352, p0353, p0354, p0355, p0356
  4. Apr 2, 2015 at 1:11 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Plugs only last 30k miles and would be a good place to start. Then clean the MAF and TB
  5. Apr 2, 2015 at 2:10 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    yes do all this
    change plugs (a too-large spark gap from old copper plugs stresses the coils)
    clean throttle body
    clean maf
  6. Apr 2, 2015 at 2:11 PM
    kegman
    kegman Well-Known Member
    Ron
    Regina sask canada
    tacoma trd 4x4 2007
    id guess previous owner never changed plugs at all and at 130km should be due changing for the 3rd time. Check the plugs and if you have Denso on one side and Ngk on the other side chances are they were never changed.Start with that and maf TB cleaning as said in a previous post.Those codes are all for ignition coil circuit malfunction.
  7. Apr 2, 2015 at 2:26 PM
    nd4spdbh
    SoCal
    check your grounds too.
  8. Apr 2, 2015 at 2:59 PM
    Cory
    Cory [OP] Member
    09 Tacoma TRD Sport
    Thanks for the replys! I will try swapping plugs, I appreciate the input
  9. Apr 2, 2015 at 3:09 PM
    Tacoma Mike
    Southern Maine
    List all the codes given. Not just code numbers.
    Anything like coil b secondary circuit ???
    What scanner did you use.
    Can you get the freeze frame data ???
  10. Apr 2, 2015 at 4:07 PM
    Cory
    Cory [OP] Member
    09 Tacoma TRD Sport
    Yes it was coil a,b,c,d,e,f secondary circuit, it wouldn't freeze frame the data
  11. Apr 2, 2015 at 4:17 PM
    Tacoma Mike
    Southern Maine
    Sounds like you have a coil going out.
    One coil will shut down a engine.
    Toyota scan tool can save the freeze frame and help pick the right one.
    You can try to ohm out the coils but more often unless it's real hot and dead it's going to be tough to get the coils out and ohmed before it comes back on line.
  12. Apr 2, 2015 at 5:07 PM
    Cory
    Cory [OP] Member
    09 Tacoma TRD Sport
    Why would it bring up a code for every coil pack of it's only one faulty one??
  13. Apr 2, 2015 at 5:38 PM
    Tacoma Mike
    Southern Maine
    Because it can. It's electronic. You short out an ecu circuit strange things happen internally.
    As a first check I would look at the tops of the coils and look for one that doesn't look like the others.
    Cracked
    Discolored
    Bulge
    Start there.
    You may want to consider letting someone do a little diag on it. Can save you money in the long run.
    I'm not saying it's 100% a coil. I'm saying I have fixed this issue with one coil. The same issue was fixed with an ecu. I'm sure other demons will throw things like this.
    I'm hoping its a one coil issue but some testing, checking, and driving will be needed.
  14. Apr 2, 2015 at 6:03 PM
    Cory
    Cory [OP] Member
    09 Tacoma TRD Sport
    Absolutely, I really hope it's just a coil and not the ecu...
    I did erase the codes and one remained, coil F but it only happened once so I will try getting it hot and ohming it out.
  15. Apr 2, 2015 at 6:09 PM
    Tacoma Mike
    Southern Maine
    Perfect.
    That's exactly what needed to be done.
    #6 coil.
    Halfway there buddy.
    If it was me you can do this one of 2 ways.
    Get a new coil for #6 or swap the coil for another hole and see if it changes
  16. Apr 3, 2015 at 5:28 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    be sure to change plugs!!!
    you need to find out if a broken or melted plug is under any coil
  17. Apr 4, 2015 at 10:56 AM
    Cory
    Cory [OP] Member
    09 Tacoma TRD Sport
    Just did a bit of playing around by unplugging individual coils and it did not simulate the issue I'm having, it just ran rough and brought up the code for a bad coil pack
  18. Apr 4, 2015 at 11:34 AM
    Tacoma Mike
    Southern Maine
    It won't
    Has to be all together and driven.
    Ecu measures circuit stability etc.
    Your not doing anything but wasting time.
    You got your first clue. Run with it.
