09 Tacoma Trouble Codes With No lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dr. Hankenstein, Jun 9, 2019.
  1. Jun 9, 2019 at 2:51 PM
    Dr. Hankenstein
    Dr. Hankenstein [OP] Member
    Hello,
    I just joined the forum and and am hoping to become a Tacoma owner soon. I looked at a 2009 SR5, 5 speed Manual, 4 cylinder, 4WD with 99,000 miles. I really liked the truck. It was pretty clean and well maintained. Some rust, but better than many of the same age in Upstate NY. The main issue I want help with is that the mechanic I had look at it scanned it with a good Autel scan tool. It had numerous codes active in the 4WD system. The 4WD engaged and worked fine. There were no engine, ABS, or traction control lights on. The mechanic thought it might just be a fluke/anomaly especially when he could not actually erase the codes. I'm looking for advice if anyone has experienced anything similar? Could these be real codes even if no lights are actually on or is one of the computers failing? Should I just walk away?
    The codes are as follows
    1. C0371-Yaw Rate Sensor
    2. C1271-Low output signal rf speed sensor
    3. C1272- Low output signal lf speed sensor
    4. C1273- Low output signal rr speed sensor
    5. C1274- Low output signal lr speed sensor
    6. C1275- Abnormal change in output signal of rf speed sensor
    7. C1276- Abnormal change in output signal of lf speed sensor
    8. C1277- Abnormal change in output signal of rr speed sensor
    9. C1278- Abnormal change in output signal of lf speed sensor
    10. C1281- Master cylinder pressure sensor output abnormal
    11. C1282- Center differential lock position sensor
    Thanks!
  2. Jun 9, 2019 at 2:54 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Someone took out the dash and removed the bulb.
    Those codes would worry me.
  3. Jun 9, 2019 at 3:01 PM
    Dr. Hankenstein
    No the dash lights are fine, when you turn the key from Accessory to On they all light up as expected.
  4. Jun 9, 2019 at 6:09 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    I generally like Autel scan tools, I personally own an MD802. But I will say, their hacked-ass software will occasionally do some weird stuff, although I can't say I've ever witnessed it with Toyotas. But I've seen it either refuse to connect, or pull up weird stuff that other scanners didn't, on Nissans and some Euro cars.
    The fact that it can't erase them would have me wondering if it didn't get fooled by digital ghosts. Like... those last 2 I don't even think are a thing on that truck...
    Edit: Googled the C1281 & 1282, the C1282 did bring up some hits mentioning part-time 4WD (which the Tacoma has) but also made reference to the "skid control ECU (master cylinder actuator)", as did the C1281 code, which would be the TRD-OR/VSC-equipped electro-hydraulic booster-M/C. I also only saw either mentioned in reference to 3rd gen Tacomas. Makes me scratch my head if he selected the vehicle wrong, or just went in in a way that it was looking for things that the truck doesn't have. Unless it's a real oddball that has that VSC master cylinder thing.
  5. Jun 9, 2019 at 6:30 PM
    Dr. Hankenstein
    I could not find the last two as sensors that exist on Toyota OEM parts sites for this truck.
    The mechanic did also say that he has occasionally seen weird stuff show up when he plugged in the scan tool. I’m inclined to believe it.
    If they were real codes I assume there would be some kind of dash lights on or something would not work. Mostly seeking clarity on the subject.
    MyhotTaco likes this.
  6. Jun 17, 2019 at 8:46 AM
    MyhotTaco
    MyhotTaco Member
  7. Jun 17, 2019 at 9:19 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    If you are still thinking of getting the truck get a different scanner and scan it and see what you get.
  8. Jun 17, 2019 at 9:29 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    those are critical codes and won't be pending, they'd each light up the MIL immediately
    also you'd be in limp mode and truck will run slow or not at all
    I am going with: improper scan
    chuck an old skool 25 dollar OBDII on there and get codes from it to cross reference that other one
