09 Tacoma window jamming
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thomann, Apr 12, 2016.
  1. Apr 12, 2016 at 1:47 PM
    thomann
    thomann [OP] Member
    Recently my drivers side window started jamming up about half way down. Everything works great in the first half of travel but about mid way down it starts to slowly bind up until it comes to a stop.
    I took the door apart to have a look for any signs of wear or any obstruction, but there was nothing to be found.
    This is causing a serious problem when getting my morning coffee, so any help would be greatly appreciated!
    Thanks
  2. Apr 13, 2016 at 3:37 PM
    thomann
    thomann [OP] Member
    nobody run into this problem?
  3. Apr 13, 2016 at 4:43 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The issue could possibly be in the gear train for the window mechanism.
  4. Apr 14, 2016 at 3:45 PM
    thomann
    thomann [OP] Member
    Had a quick look at it with the door panel off and it looked ok. I will pull it apart this weekend and have a closer look. Thanks.
  5. Apr 14, 2016 at 7:02 PM
    Tacosioux
    Tacosioux New Member
    Had the same exact problem on my 2010. They said the regulator arm was bent-place where I bought it fixed it. Good luck.
  6. Jun 2, 2016 at 2:50 PM
    Mattmcgyver
    Mattmcgyver Member
    Maryland
    '12 TRD Crew Cab
    None yet
    Does anyone PM the power window? Panels on or off?
    M
  7. Jun 2, 2016 at 2:54 PM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    There is a thread on this every other week and there is a TSB on it in the TSB sticky.
