09 tacoma with toytec 3"lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whitetacoma1, Aug 19, 2010.
  1. Aug 19, 2010 at 8:06 PM
    whitetacoma1
    whitetacoma1 [OP] White Tacoma 4X4
    Dan
    Alberta
    2009 and 1997 tacoma 4x4
    3" toytec Lift front OME 885s and AAL in the back
    09 tacoma 3" lift with 885's in the front with spacer and AAL in the rear. going to look for tires tomorrow.
  2. Aug 19, 2010 at 8:16 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Looks good! :)
    Cant wait to get my DBl Cab LB!
  3. Aug 19, 2010 at 8:18 PM
    tacosupreme54
    tacosupreme54 Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    the new tires will make it look like a new truck man! go with 285's!
  4. Aug 19, 2010 at 8:19 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    nice.... what kinda tires you considering? Size?
  5. Aug 19, 2010 at 8:20 PM
    whitetacoma1
    Dan
    Alberta
    285s will they fit on the factory rims or do you need spacers?
  6. Aug 19, 2010 at 8:22 PM
    whitetacoma1
    Dan
    Alberta
    I have been looking at BFG At's not sure what size yet I want to go up atleast to a 32= But I am also wanting to use to Factory rims for now.
  7. Aug 19, 2010 at 8:25 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    well a 32 will be fine on a sport rim. and some people have ran 285's on stocks. not sure if it's safe or reccomended. but the spacers will help it work too
  8. Aug 19, 2010 at 8:32 PM
    whitetacoma1
    Dan
    Alberta
    I do alot of Hwy driving so I dont want to go really big, I learnt that the hard way with my 1997 Tacoma I did a 6 inch lift with 33 and it just sucked the gas back.
  9. Aug 19, 2010 at 8:39 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    well do a 32", that's what is on mine and it looks pretty good to me (look in sig.). but anything less with that lift will look goofy to be honest. the 33" (285) is a little bigger/heavier, so it will have a little more mpg loss. but really not significantly more than the 32". just my standpoint.
  10. Aug 19, 2010 at 8:46 PM
    whitetacoma1
    Dan
    Alberta
    I agree. Thanks Tacosupreme54.
  11. Aug 19, 2010 at 8:52 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    no prob, post pics to this if you get some put on tomorrow!
  12. Aug 19, 2010 at 9:00 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    King RR w/adjusters, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Go 285 duratracs, they are like $200 each.
  13. Aug 19, 2010 at 9:29 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    go 32"s. no rubbing or trimming as you do with 285's. i have 3" also
  14. Aug 19, 2010 at 9:38 PM
    whitetacoma1
    Dan
    Alberta
    Thanks guys! nice trucks by the way
  15. Aug 20, 2010 at 8:16 PM
    whitetacoma1
    Dan
    Alberta
    I went with 32 inch BFG ATs I get them put on tuesday
  16. Aug 20, 2010 at 8:20 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    16 T4R Trail
    In need of $$$
    What UCAs did you go with?
  17. Aug 20, 2010 at 8:26 PM
    whitetacoma1
    Dan
    Alberta
    did need to go with Any UCA with the OME coils.
  18. Aug 20, 2010 at 8:43 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    gonna look good, don't forget the pics!
  19. Aug 20, 2010 at 8:43 PM
    raycie
    Oahu, HI
    16 T4R Trail
    In need of $$$
    did you do alignment yet? if so, what were your specs? Reading a bunch, it has been mentioned multiple times that even a 2.5 would need new UCAs to get proper alignment..
  20. Aug 20, 2010 at 8:50 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    yeah, i've heard that some are doing fine without new uca's. but most ppl need them. i'm one of the one's that need them... :(. my front tires/wheels point slightly inward (OP should check and see if his do), it sucks that they cost so much, but they will def. have to be my next purchase. it won't really hurt you too bad if you go without them for a decent amount of time, your tires will just wear unevenly, have bad angles, and alignment won't be just right. i know mine does anyway, i get a slight vibe between 0-20mph bc the alignment is getting off and bc the tires need to be balanced/rotated due to uneven wear. as long as you don't ride like this for a while, you're good, just make uca's your next buy.
