09 Toyota Tacoma will not start when it's cold out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sis72x, Mar 11, 2017.
  1. Mar 11, 2017 at 12:54 AM
    Sis72x
    Sis72x [OP] Member
    New Jersey
    09 Toyota Tacoma trd sport v6 4.0l
    6 inch lift k&n intake and full exhaust
    I was wondering if anyone could help me out my truck will not start when it's cold out I've been dealing with this for about four months now I've replaced the Ecm check all the fuses relays traced wires fuel pump control module the dealer had it for a month and they can't figure it out I've replaced the crank sensor I'm not getting any codes I'm losing my mind with this truck. I cleaned the throttle body mass air flow my next step is temp sensors. When the truck starts it runs fine no problems I hope someone has some input on this
  2. Mar 11, 2017 at 1:04 AM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    How cold is it when it won't start? Mileage?
  3. Mar 11, 2017 at 1:57 AM
    Sis72x
    Sis72x [OP] Member
    New Jersey
    Around 30 degrease and below the mileage is 130,000 if I pull it in the garage for about a hr with the heat on it will start right up and run fine I checked the cold start injectors and the ohms were 6.8
  4. Mar 11, 2017 at 2:22 AM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    It cranks and won't start? Or just won't turn over at all? Have you tried with a different key, could be the engine immobilizer/chip in the key acting up.
  5. Mar 11, 2017 at 2:49 AM
    Sis72x
    Sis72x [OP] Member
    New Jersey
    It cranks and cranks it loses injector pulse the immobilizer is good light goes out when I put the key in the ignition tried three different keys and re programmed them as well it's reading everthing ok on the scanner I did have one time o2 sensors were reading -40 degrease but no codes
  6. Mar 11, 2017 at 2:53 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe try a new coolant temperature sensor
    07 sport 4x4 likes this.
  7. Mar 11, 2017 at 3:14 AM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Check out this thread, almost sounds like your issue, page 12 and 13 for solution from the OP.
  8. Mar 11, 2017 at 7:25 AM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    Most likely your battery need to be change.
  9. Mar 11, 2017 at 7:41 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    How many miles on the spark plugs?? When it is cold, the air is more dense. This may lead to a bit higher compression in the pistons. The higher the compression, the tougher it is to fire a plug.
    Happened to me once and a spark plug replacement made all good again.
  10. Mar 11, 2017 at 7:56 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Remember the magic triangle of life for an engine. Air, Fuel ,Spark. Obviously you're getting air because it runs when warm. Just need to verify whether your not getting spark or fuel. Spark is an easy test. Start working back from there.
  11. Mar 11, 2017 at 10:39 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Fuel, compression, spark. Fuel is air and gasoline, combined at or near a 14.7:1 ratio ideally, but a bit richer for cold starting (10.5 to 11.5:1 is common)...
  12. Mar 11, 2017 at 12:05 PM
    Sis72x
    Sis72x [OP] Member
    New Jersey
    I ordered a coolant sensor last night I'm going to pick it up later today I really don't think it's the coil packs because when it does start it runs good and it will run all day let it sit at night and willnt start
  13. Mar 11, 2017 at 12:07 PM
    Sis72x
    Sis72x [OP] Member
    New Jersey
    The plugs r not that old I replaced them in the spring I know I'm losing injector pulse
  14. Mar 12, 2017 at 12:26 PM
    Sis72x
    Sis72x [OP] Member
    New Jersey
    Ok it wasn't the temp sensor it wouldn't start all morning till the sun warmed the cab up wth am I losing my mind now with this truck
  15. Mar 12, 2017 at 1:17 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Did you look at the thread I linked? Post #7
  16. Mar 12, 2017 at 2:34 PM
    Sis72x
    Sis72x [OP] Member
    New Jersey
    Yea I did that's going to have to be the next step again it was checked before by the dear and they keep telling me it's not the immobilizer but who knows at this point what I was thinking is wait till night when it doesn't want to start and put a space heater in the cab and see if it will start
  17. Mar 12, 2017 at 3:25 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Next step, make sure your insurance is up to date and hope the space heater catches it on fire?
    Just kidding, hope you figure it out.
  18. Mar 12, 2017 at 3:30 PM
    Sis72x
    Sis72x [OP] Member
    New Jersey
    If I could be so lucky lol
  19. Mar 12, 2017 at 3:40 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
  20. Mar 12, 2017 at 3:50 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
