09 transmission coolant line
Discussion in 'Technical Chat' started by linkfeeney, May 17, 2023.
  1. May 17, 2023 at 5:10 PM
    linkfeeney
    linkfeeney [OP] Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    hi
    anyone here had any issue with the transmission coolant line leaking? My rotted out..
    I brought it to my mechanic, he replaced the line and hose..I cleaned the skid plates... I noticed it still leaking, well its pooling a little areas on the skids plates, not sure on where else it is coming from.... IIm going to bring it back to him tomorrow to look at this again...
    my truck is literally rotting away... is there leak detection for this? thx
    TOMB likes this.
  2. Jun 11, 2023 at 10:01 AM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    This may sound out of left field but try this.
    Clean everything where you think the leak is coming from, now the out of left field.
    Purchase some spray deodorant that has powder in it, might find it in the woman's area of the store the powder will attach itself to the leak, sort of like a die detector (result is similar to how you check for an AC leak).
    It sounds crazy but it's a cheap solution for the result you're looking for as the powder is usually white not invisible and the $$$ is minable outlay.
    TOMB
    Bivouac likes this.
  3. Jun 12, 2023 at 2:19 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Steering Rack or pump or assorted lines leaking ??
    As it is ATF.
