09 TSB's Approved :)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Major91, Jun 10, 2010.
  1. Jun 10, 2010 at 11:42 AM
    Major91
    Major91 [OP] Well-Known Member
    Masshole
    2009 TRD OffROAD Barcelona Red
    On Anytime Fog Lights Satoshi Grillcraft Misc LEDS 5100's all around Konig's16". Duratracks, debadged,tinted fronts, custom shifter, flyzeye
    After doing my homework on the rear leaf spring TSB, automatic transmission TSB and the rear leaf squeak TSB i have been just notified that all 3 TSB's have been approved and parts are now on order.
    So anyone who is having an issue with the squeaking in the rear end i would suggest having them look into it. I did not know there was a TSB for that. :thumbsup:
  2. Jun 10, 2010 at 11:51 AM
    Coloradomx24
    Coloradomx24 Well-Known Member
    Colorado
    2015 Dbl Cab L/B Sport
    Will it make a difference on them approving this for my truck if I have a spacer lift and aftermarket rims?
  3. Jun 10, 2010 at 11:57 AM
    Major91
    Masshole
    Not sure on either. I would do some research in the forum and see what others have had issues with when they had non stock items on there trucks. I do not think rims would make the dealer swing one way or another. I called Toyota first and explained to them my issue when driving with about 400 pounds in the back. I used the word 'safety' concerns and well.......was given a case number. Next step was to contact the dealer. Don't tell them you have a TSB and want things fixed. Explain to them your issues and tell them when you called Toyota they ref you to the TSB. They cannot do anything but add the rear leaf spring for safety concerns.
  4. Jun 10, 2010 at 12:15 PM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    Major who are you bringing it to? My 09 just started to squeak. I work in Worcester.
  5. Jun 10, 2010 at 12:17 PM
    Major91
    Masshole
    From the dealer i bought my truck at Tri State Toyota in Dudley Mass hey!
  6. Jun 10, 2010 at 12:20 PM
    Danosabre
    Dan
    Gardner,Ma
    09 TRD Off Road
    Good to know just in case HARR Toyota doesn't do mine. Thanks!
  7. Jun 10, 2010 at 12:24 PM
    Major91
    Masshole
    To me i sounds like the squeaking issue has been around for some time. I have not seen a TSB on this but Sean who is the head service guy told me right off the bat there is a 'kit' for the squeak issue. Mine is only when its dry out. So figures it rains today. No issue....they ordered the parts and i will schedule everything for one day.....
  8. Jun 10, 2010 at 12:27 PM
    white91formula
    white91formula Well-Known Member
    Boston, MA
    05 6speed TRD OR
    brought mine to Harr and had absolutely no problems..... once they updated it to include the 09's :rolleyes:
  9. Jun 10, 2010 at 12:56 PM
    Major91
    Masshole
    So i just picked up my truck. Like i said parts are on order. So they say the squeaking is caused by 'plates' that are not in between the rear leaf springs that when, rust or particles get in between you will get the issue for sure. So when the TSB is done when the leaf springs and other parts are added will be done all at once. :p
  10. Jun 10, 2010 at 2:44 PM
    ETAV8R
    ETAV8R Out DERP'n
    Republik of Kalifornia
    MGM 09 AC 4WD V6 TRD-OR w/ 2013 FWC Finch
    Grillcraft, Demello Sliders, Bilstein front and rear with OME coils and springs, Wheelers Bumpstops front and rear
    Are there numbers for the TSBs? Does this need to be done before the factory warranty expires?
  11. Jun 11, 2010 at 4:52 AM
    Major91
    Masshole
    Yes for the ECM CALIBRATION - T-SB-0373-09
    Rear Spring Harsh Ride - T-SB-0305-08
    Both can be located on this site.
  12. Jun 11, 2010 at 6:13 AM
    motopilot
    motopilot Well-Known Member
    Central FL
    '10 DC TRD SPORT
    Just got the Spring TSB. Drove into the dealership weds evening. They got the parts thrusday am and it was done by 12:00. Great service and no problems what so ever. Did it at David Mauss Toyota in Sanford where I bought my truck. They were very good and professional about this. Said my '10 was not in the list for the TSB to reflash as it was newer than the VIN's on the TSB. Going to double check but very happy with the springs. Firmer ride but like it. Rear sits up a little higher as well. Here are a couple of pics. Sorry was camera phone.
  13. Jun 11, 2010 at 6:15 AM
    Major91
    Masshole
    Sweet! Looks good and cannot wait till mine get done to feel the ride difference.........
    Hopefully i'll have mine by Monday!
  14. Jun 11, 2010 at 6:37 AM
    Major91
    Masshole
    Also another note, had the transmission reflashed and let me say. This truck rides so much better now. 110% difference for sure........no more head jerking around from a stop.....
  15. Jun 11, 2010 at 6:40 AM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
  16. Jun 11, 2010 at 6:51 AM
    Major91
    Masshole
    That was done at 1000 miles. I had a knocking going on with my steering column going over bumps.....dealer could not figure out what was doing this so they replaced the entire column and never had that happen again.
  17. Jun 11, 2010 at 6:54 AM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Hey Guys
    You have 09s, and 10s.... I have an 05, and bought it used... can I still take it to a Toyota dealer for the TSB?
    Cheers
  18. Jun 11, 2010 at 12:38 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    Is there an actual TSB# for the rear leaf squeak? I've been trying to find one, but no luck. I've found one for the rear leaf suspension and another one for the ECM reflash, but not one for the squeaking, specifically.
  19. Jun 11, 2010 at 12:41 PM
    Major91
    Masshole
    I have not found one but when i drop my Taco i'll ask the dealer for the number. I might even have it on my paperwork at home.
    But for sure it seemed to me that its a well known issue with the missing plates in between the leaf springs.
  20. Jun 11, 2010 at 1:52 PM
    iSTIZO99
    Jax, FL
    Sounds good, keep me posted...thanks!
