09 XM Radio Install
Discussion in 'Audio & Video' started by abnchief, Jan 2, 2009.
  1. Aug 23, 2009 at 2:59 PM
    Tacoma-09
    Tacoma-09 Well-Known Member
    Ft Lauderdale, Florida
    09 Taco TRD Sport DC
    Sorry to necro this thread, I just needed to answer this post.
    No my head unit is not an after market head unit. The entire XM install is 100% Original Toyota parts
  2. Oct 22, 2009 at 4:12 PM
    BRAIN
    BRAIN New Member
    Tennessee
    white
    do you need the fit kit if truck is already prewired with antenna
  3. Oct 22, 2009 at 4:16 PM
    CRIMAR30
    CRIMAR30 2016 TRD SPORT
    MARK
    NORTH CAROLINA
    2016 TRD SPORT ACCESS CAB
    I installed mine last weekend, was about $240 for everything, much better than the $699 the dealer wanted to do it.
  4. Oct 23, 2009 at 1:07 PM
    Tacoma-09
    Yes you do. The fit kit is basically the wire that runs from the XM tuner to the Antennae plug under the drivers side kick panel.
  5. Oct 23, 2009 at 1:17 PM
    hendross
    hendross Member
    This IS NOT the same for sirius
  6. Oct 23, 2009 at 1:23 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Why so much? With parts it cost me likle $250 cheaper than that at my dealer.
  7. Oct 23, 2009 at 1:41 PM
    Tacoma-09
    @hendross - Yup it is different for Sirius. This thread is about the XM install hence my answer to Brian is that for the XM install you need the fit kit.
  8. Nov 18, 2009 at 3:25 PM
    D Train
    D Train Well-Known Member
    Texas
    TRDsport
    I wanna say thank you!!! After reading this post and seeing all the pictures I was confident enough to go out and find the right parts at a good price and the knowledge to confidently install mine on my own. I installed mine lastnight and it works like a champ!!!! Thanks again!
  9. Nov 18, 2009 at 5:42 PM
    Tacoma-09
    Glad it helped you
  10. Nov 29, 2009 at 6:16 PM
    jonny_toyota
    jonny_toyota Taco Sales Guy
    JON
    Guelph, ON
    Magnetic Grey 4X4 4cyl. SR5 Power Package
    Toyota running boards, soft-folding tanneau cover, hood deflector, box cargo net, Weathertech Tray Type Floor Liners, XM Radio, bluetooth, Eclipse AVN726E, IV DrawTite Hitch, 16x8 Moto Metal 951 Chrome with 265/70R16 BF GOODRICH A/T K/O, READYLIFT 2.25" Front Leveling kit, Toyota Assessory Skid Plate, Front doors tinted, 10" Alpine Type R in a DIY down firing sub box powered by a Alpine V12 MRVT502.
    Q - Hey, does anyone know if the the Toyota XM will still work if you up grade the head unit to a double din? I'm thinking it should with the proper harness but I'm not sure. I am installing a new Eclipse AVN726E on Wednesday. It sure would suck to have to take out the Toyota XM receiver and buy an Eclipse one.
  11. Nov 30, 2009 at 6:14 AM
    dannyd1972
    dannyd1972 Active Member
    Nashville,TN
    09 PreRunner SR5 Magnetic Gray
    I hate to be the bearer of bad news...but no, the factory XM module will not work with your new head unit. I recently replaced my stock head unit with a Clarion double din with high hopes myself. The wiring harness from the XM module (located under the rear passenger side storage compartment in my Access Cab) has it's own separate harness that plugs directly into the factory receiver. Also, it appears the module itself is powered by factory receiver in addition to having ZERO external outputs. I had to purchase both the aftermarket XM (in my case Sirius - I prefer their programming) as well as the Clarion interface. However, I was able to salvage the factory satellite antenna wire from the old XM receiver and modify it to work with my new Sirius unit. A big plus considering that single wire uses a rather pricey, unique plug (located behind the driver side kick panel). If you can solder at all then you should be able to do it. Good luck!
  12. Nov 30, 2009 at 6:01 PM
    jonny_toyota
    JON
    Guelph, ON
    I appreciate the info man. Maybe I'll be luck and the Eclipse AVN726E will be different. Thanks again.
  13. Dec 13, 2009 at 9:12 AM
    vehiclewrapper
    vehiclewrapper Member
    Vehicle Wrapper
    White Plains NY
    it appears that the head unit is exactly the same, just curious if anyone has used this thread/instructions on a 10. thanks, and great thread.
    the only question that i have is this, do you need to run a cable from the xm receiver all the way to the back of the stereo head unit, or is there a connection in the kick panel for that as well (along with the antennae). i noticed that (potential) step was left out of the tutorial so i am hoping that is the case.
    here are my 2 cents in regards to parts/instructions:
    http://www.toyotapartscenter.net/
    OEM Catalog PT546-35090 FIT KIT XM TACOMA $80.00
    OEM Catalog 86180-0W031 211M XM RECEIVER 159.20
    remove stereo faceplate tutorial:
    http://www.*********.com/installation/tacomadash/index.html
    http://www.tacomaworld.com/forum/audio-video/22644-09-xm-radio-install.html
    -shad
    www.vehiclewrapper.com
  14. Dec 26, 2009 at 6:11 PM
    tmccoy
    tmccoy New Member
    Travis
    Louisville, KY
    PreRunner TRD Long Bed
    FYI, I just did this install today on my '10 Double Cab. Everything went without any problems, probably took only 30-40 min.
    Travis
  15. Dec 27, 2009 at 4:13 PM
    #35
    vehiclewrapper
    Vehicle Wrapper
    White Plains NY
    thought so, thank for confirming it. time to place the order.
  16. Jun 23, 2010 at 7:15 PM
    #36
    mcnick5
    mcnick5 Member
    TRD sport
    hey, i am currently trying to do this install on my '10 double cab. after you remove the aux box how to you rout the cables up to the driver's door channel? thank
  17. Jul 10, 2010 at 8:59 PM
    #37
    Pcd225
    Pcd225 Active Member
    New Orleans
    2010 PreRunner
    Does anyone know if the install is different in a 2010 access cab Tacoma?
  18. Sep 27, 2010 at 6:47 AM
    #38
    tarheelfan_08
    tarheelfan_08 Carolina Alliance
    Justin
    North Carolina
    2010 White 4x4 Double Cab Tacoma Short Bed
    Chrome Grill, Chrome accessories(door handles and mirror covers), LEER Super White Cover, Mirrors with Turn Signals, Window Vent Visors, Step Rails, WeatherTech Digital Floor Mats, Mini Maglight Holder, Chrome Bull Bar
    So if I am correct the only thing you have to do is mount the box under the back seat then run the wires to the kicker panel? No taking off the stereo or cover or anything?
  19. Sep 27, 2010 at 7:05 AM
    #39
    Tacoma-09
  20. Sep 27, 2010 at 7:12 AM
    #40
    tarheelfan_08
    Justin
    North Carolina
    Then I will definitely be buying the parts from a fellow member and doing this in my new double cab!!!!!! Damn Toyota for installing the antenna, and having it XM ready but not finishing it. That is just shitty building!
