0W-20 in a 1GR-FE?
Discussion in 'Technical Chat' started by dysfunctnlretard, Jun 28, 2010.
  1. Jun 28, 2010 at 11:28 AM
    dysfunctnlretard
    dysfunctnlretard [OP] Hi
    Manny
    CA
    2021 Jeep Rubicon
    I was flipping through my owners manual this morning and noticed that it calls for 0W-20 engine oil?
    I thought our engines were supposed to be using 5w-30?
  2. Jun 28, 2010 at 11:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    For the FJ, they specify that grade to get the mpg rating it has.
  3. Jun 28, 2010 at 11:32 AM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    :eek:. If its not too much trouble, how does oil vicosity affect mpgs? Im assuming the more viscous it is, the more energy is consumed in moving the pistons which means a loss of MPGs? So less viscous translates into more mpgs?
  4. Jun 28, 2010 at 11:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The crank creats the most drag in the oil. IIRC, the thinner the oil, the easier it is for the engine internals to spin, thus giving better economy.
  5. Jun 28, 2010 at 11:43 AM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    Makes sense but arent I sacrificing protection at that point? I just think its weird that they would prescribe 2 different oil weights to the same engine. I mean if 0-20 is sufficient why not market the Tacoma with higher MPGs by prescribing it 0-20 oil. I know Tacomas tow but FJ towing capacities are over 5klbs too, not a huge difference.
  6. Jun 28, 2010 at 11:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    In my opinion, I belive you are sacrificing protection. I have no proof of this though.
  7. Jun 28, 2010 at 11:51 AM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Yeah, why risk it?
    5w-30 in and watch how you use the throttle.
  8. Jun 28, 2010 at 11:52 AM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    Damn. This is stresssing me out... Should I go with common sense or what the automakers tell me? LOL
  9. Jun 28, 2010 at 11:52 AM
    jandrews
    '09 FourDubDee TRD OR
    Both tow, but Tacos haul, which is where the real stress is. Think about carrying 80lbs on your back or in your arms vs. pulling it on a handtruck. That extra stress is probably why Toyota recommends a slightly heavier weight for the Taco.
    Honestly, I think you'd be hard pressed to kill either vehicle using either weight.
  10. Jun 28, 2010 at 11:58 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I agree. At operating temp there isn't much difference between the two. I would run whatever Toyota wants me to.
  11. Jul 7, 2010 at 11:42 AM
    anamouse
    anamouse New Member
    Los Angeles
    Tacoma 4 cyl Manual xtra cab
    Shell, and killer 100 watt fog lights were stock fog lights should be.
    Toyota recommends 0 wt 20 oil or 5 wt 20 oil in my 2009 4 cyl tacoma and that has me worried.
    I live in a hot climate and asked the dealer if I could move up to 5 wt 30 oil, and told them I wouldn't mind loosing a little mileage to get a little better protection and perhaps a little longer engine life.
    They told me I could not put 5 wt 30 oil in my engine because the oil in the 09 engine does more than just lubricate the engine, it also moves actuators, and if it was a heavier weight oil it will not let the engine operate properly.
    Bottom line, I'm stuck with 5 wt 20 and can't do anything more to protect the engine more. I sure hope it doesn't result in a short engine life.
  12. Jul 7, 2010 at 11:49 AM
    BuckNakedBooda
    BuckNakedBooda There's no place like 127.0.0.1
    Woodbridge, Virginia
    2013 Toyota Tundra Crewmax Limited 4x4
    Throwning in some zMax can help you out. I have used it in all of my vehicles for the last 20+ years...
    I purchase the 32 OZ bottles of zMax. They can be used in your oil, gas and transmission.
    I don't buy the kits that you see in stores such as Auto Zone and Pep Boys with the different colors of zMax.
  13. Jul 7, 2010 at 11:53 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    Oil flow is just as important as oil viscosity when it comes to protecting your engine. If your oil is too thick, it won't flow properly through the engine. Having said that, the earlier 2.7s used 5w30, so I doubt running it in the new 2.7 would be a problem, but why risk it. 5w20 will protect your engine fine.
    Here's some great research on oil that has been posted many times on TW. It's a long read, but full of info.
    http://ferrarichat.com/forum/faq.php?faq=haas_articles#faq_motor_oil_basics
  14. Jul 8, 2010 at 10:52 AM
    Dudley
    Dudley Cranky Old Bastard
    David
    Texas
    10 Access Cab
    You may want to go here http://www.bobistheoilguy.com/cms/ and read the oil course. It may lower your stress factor. I used to be a subscriber of the thicker is better school of oil selection. Maybe not so much now. Apparently oil viscosity numbers become closer the higher the oil temperature. The trick is to get it to flow at cold temps.
  15. Jul 8, 2010 at 10:57 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I used it in my 09 Mobil one 0-20 full syn.
    My 2010 still has Factory oil in it and I have the free change deal so I am not sure when I will be switching on the new one.
  16. Jul 8, 2010 at 11:38 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    I am running 0-30 amsoil sig series with a mann filter.......oil gets changed every year or 35,000 miles......filter every six months
  17. Jul 9, 2010 at 3:16 PM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    GM has many years of data to prove that the 5w20 and 0w20 are providing adequate protection. All the other manufacturers are warming up to the idea as can be seen in the recommendations from several high quality manufacturers (Honda, Toyota, et al)
    As was posted before oil flow rates are playing a role
    All in all for heavy duty applications in hot environments or lots of idleling will stress the oil more but those conditions were also included in the data GM has developed so it is fine -- I guess...
  18. Nov 16, 2011 at 6:19 AM
    Balien
    Balien Well-Known Member
    Central Canada
    TRD Tacoma auto, long box in red
    lighted 4x4 switch, python alarm/starter, weather tech matts, bug and rock deflector, , kuda cell phone mount in matched grey. DMV2 Tires, Bilstein 5100 lift, Icon RXT leafs. Sprayed the frame with Rust Check All the time.
    I found this chart that allowed 0w20 sythetic in the 1gr-fe v6 engine and goes exclusivly to it in 2011, 2012. It supposedly came from toyota canada but I can't find it on their web site directly. I think thats how they managed to change the fuel economy slightly. This is confusing as it is directly wrong to the other chart that doesn't allow it in the V6 engine. Perhaps it's the cold weather up here in Canada. not sure. Anyone got this oil put in at the dealership?
    http://pdfcast.org/pdf/toyota-oil-recommendation
    http://www.google.ca/url?sa=t&rct=j...6_zHDg&usg=AFQjCNHexaEesQvX17R-BBaaF-5hL_7qSQ
  19. Nov 16, 2011 at 6:26 AM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    It would scare me to run oil that long lol, even if that's what the manufacturer says is okay :D
  20. Nov 18, 2011 at 10:03 AM
    Dudley
    David
    Texas
    10 Access Cab
    I believe that Toyota recommends the lighter stuff as opposed to the 30wt because of the VVTI technology. Oil weight apparently can affect cam timing responsiveness. The oil pressure driven servos that control cam timing are oil weight sensitive.
