0W-20 vs. 05W-20 in the 2.7L, does it really matter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pearson, Oct 23, 2021.
  1. Oct 25, 2021 at 7:58 PM
    #41
    Pearson
    Pearson [OP] Well-Known Member
    Elliott
    Lexington Texas
    Black 2012 2.7L Prerunner
    Yeah me to where the valve cylinder head gasket are concerned. The OEM exploded view describes the two gaskets involved as Cylinder Head Cover Gasket and Cylinder Head Cover Gasket no 2. I most likely crapped that up trying to say it right.
    I'm with you though, they are "Valve Cover Gaskets".
    I was actually thinking about a clean-up to make sure that what I suspect is actually a contributor to the oil I see on the block.
    I absolutely will be knocking out the PCV while I'm in there for sure. As well as anything else you guys can think of while I am in that far.
    So please reach out if anything comes to mind before it's too late.
  2. Oct 27, 2021 at 8:50 PM
    #42
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    If you plan on keeping it for a long time. Might not hurt to replace the coolant bypass pipe with the metal one. First they get a small crack and very small coolant leak. It runs under the intake manifold up to the front of the motor near the thermostat. It could have already been done they are common to fail on the 2nd gen 2.7
    Pearson[QUOTED][OP] likes this.
  3. Oct 27, 2021 at 11:17 PM
    #43
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    His 2012 should already have a the metal pipe.
    Pearson[OP] likes this.
  4. Oct 28, 2021 at 6:51 AM
    #44
    Pearson
    Elliott
    Lexington Texas
    Just saw this, thanks toyodajeff. This is the kind of information that if we know, we need to share, very helpful. Does anyone have an exploded view part numbers etc of exact location???
    I do plan on keeping her for now, but I do see myself going to a 4wd in the future. Love the idea of an adventure truck. But even with that, the truck is overall in excellent condition and deserves to be well taken care of. This way whoever ends up with her in the future will have that much less to worry about and can enjoy her all the more.
    Many thanks, and please keep this kind of information coming, it is much appreciated.
  5. Oct 28, 2021 at 7:10 PM
    #45
    toyodajeff
    jeff
    06 reg cab sr5
    https://www.tacomaworld.com/threads/water-bypass-pipe-no-1.201053/
    that’s a thread about replacing it. If yours is plastic those are the bad ones. According to the post above yours is the metal good one. That thread I linked explains the diffrence.
  6. Oct 28, 2021 at 7:34 PM
    #46
    Pearson
    Elliott
    Lexington Texas
    Got it thanks. Question though, is there a cutoff year when they no longer used the plastic? And are the metal ones a concern or prone to leak if you find that this is what you have? I have a 2012 Prerunner of course with the 2.7L.
  7. Oct 28, 2021 at 7:40 PM
    #47
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I have a 2010 with the 2.7L, and I'm currently within a day or two of hitting 140K miles...
    I first discovered mysterious oil consumption at about 107K-110K miles, so I switched to 5W20 after having run full synthetic 0W20 since 80K miles. My truck had been "using" oil at a rate of roughly a quart ever 3,500 miles or so. There were no signs of leaking or burning, and switching to 5W30 seemed to alleviate the problem for a little while, but it quickly came back.
    I've been running Mobil 1 Full Synthetic in my truck since 84K miles, and I switched to 10W30 High Mileage Formula at 135K miles. I discovered just past 139K that it was "using" oil again and replaced the PCV valve ($8.50 at the dealer); This seems to have taken care of the problem! :)
  8. Oct 28, 2021 at 7:41 PM
    #48
    Pearson
    Elliott
    Lexington Texas
    Just saw this. So if it is metal are there any failure concerns? And what was the last year they used plastic? Or was this a hit-or-miss thing throughout production?
  9. Oct 28, 2021 at 8:28 PM
    #49
    Jimmyh
    SC
    2012 Prerunner SR5
    No concerns with the metal pipe as far as I know. It uses a gasket instead of an o-ring to seal the flange end.
    I'm not sure what year they switched to metal over the plastic.
    I based my comment off the fact that my 2012 has the metal pipe in it from the factory.
  10. Oct 30, 2021 at 11:33 AM
    #50
    toyodajeff
    jeff
    06 reg cab sr5
    The metal on is the good one. The plastic ones would crack and leak.
  11. Oct 30, 2021 at 12:46 PM
    #51
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    0W-20 is the oil that will behave like 0 weight at zero degrees fanhrenheight. If you live somewhere where it gats damn cold then I would use this oil. Otherwise there is little difference between 0W-20 vs 5W-20. The oil get up to the top where it needs to be. Follow the manual on the frequency that you need to change the oil and get on with life.
