0w-20?
Discussion in '4 Cylinder' started by dawgn86, Dec 12, 2018.
  1. Dec 12, 2018 at 5:38 PM
    dawgn86
    dawgn86 [OP] Well-Known Member
    2013 Toyota Tacoma
    2013 Tacoma 65k miles 4cyl . Cap and manual calls for 0w-20 Is there any advantage of harm in running 5w-20? Live in Georgia
    Thx
  2. Dec 13, 2018 at 10:06 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Not in my opinion. I have used 5W30 in mine for years. The manual recommends that for heavy duty use.
  3. Dec 13, 2018 at 2:18 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    If you live in an extreme cold climate (below zero F), stick with 0w20. Otherwise 5w20 would probably be OK. If you live in an extreme hot climate, you might consider 5w30.
  4. Dec 13, 2018 at 3:00 PM
    dawgn86
    2013 Toyota Tacoma
    Northeast GA so I really dont get either ...Thanks
  5. Dec 17, 2018 at 8:26 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Why dont you want to run 0w-20?
    BillsSR5 likes this.
  6. Dec 17, 2018 at 8:53 AM
    dawgn86
    2013 Toyota Tacoma
    I am good with 0w-20; was just wondering if there were any advantages to something else.
    changed this weeked to Castrol Edge 0w-20.
  7. Dec 17, 2018 at 8:58 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
  8. Dec 17, 2018 at 9:29 AM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    Im new to these trucks but every shop down here in Central Florida tends to recommend the thicker oil as with our winters, 30-anything temperatures is considered the ice age down here and 0w is just not necessary which is the conditions it’s really designed for. A very well known and reputable Honda/Toyota shop in town that has serviced my wife’s Honda for years has recommended 5w in the 0w engine. It was one of the first models asking for 0w that Honda put out and it’s gotten Mobil 1 standard 5w20 for years. It’s got 160K on the clock, never had any engine issue and runs just as good and gets same mileage since it was new.
    Obviously if warranty is a concern I’d go by the book but otherwise if you live south and it makes you feel better ,I highly doubt 5w will give you any issues
  9. Dec 18, 2018 at 4:23 AM
    snowdrifter
    snowdrifter Well-Known Member
    Indiana
    11 SR5 AC 4x4
    0W20, 5W20, 5W30, are all good. I'm running 5W40... living in the midwest..... in winter. And it's fine.
  10. Dec 20, 2018 at 10:36 AM
    96carboard
    96carboard Well-Known Member
    The answer to this oil thread is this; the kind of oil you want is... the slippery kind.
  11. Dec 20, 2018 at 12:34 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    my owners manual says use 0w20 or if not available use 5w20 only till the next OCI then use 0w20, it doesn't state why 5w20 cannot be used on a regular basis and I have never figured out why using a 5w20 would be harmfull to use regularly.
  12. Jan 6, 2019 at 9:05 PM
    JoeyTaco
    JoeyTaco Well-Known Member
    This is my second 2.7. I got 417000 miles out of the first one before the frame went and the engine was running perfectly. I live in one of the coldest snowiest spot in the continental US. I see temps colder than -35f without wind chill every year. I run Mobil 1 0w40. Castrol 0w40 or Rotella 5w40 would do just as well. My suggestion would be to run a 0w30 if your not hard on your rig. If you tow and or drive at high rpms for extended periods to run 0w40. 20wt oil is the result of US CAFE standards for fuel economy. Check out www.bobistheoilguy.com.
    Get a used oil analysis from a reputable source. Don't take my word for it. My oil choices are supported by Toyota via the owners manual.
  13. Jan 7, 2019 at 5:10 PM
    Markcal
    Markcal Well-Known Member
    The owners manual for my 2006 - 2.7l says to use 5W30 or if not available use 10w30 only till the next OCI then use 5w30. I think it's all about the result of US CAFE standards for fuel economy, as ^^^ JoeyTaco stated above. IMO my truck will run just fine with 10W-30, but won't get the desired MPG and it's why they are pushing thinner and thinner oils, even if it may not be the best for my 2.7l engines longevity.
  14. Feb 20, 2019 at 8:43 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    Thin oils are for CAFE standards. Not for engine protection. I run Amsoil 10-30 Signature in my 2004 2.7 in southern Wyoming. I did install an oil pan heater as well as a battery heater. I don't "need" it below zero but why stress the starter and battery when I don't have to. I still have to start it at work when it's down around zero. I can plug it in there but usually don't. In Georgia you could easily get away with 5-30, 0-40 and probably 10-30.
  15. Feb 20, 2019 at 8:49 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Thicker oil flows slower through the VVT screen and retards ignition timing (or so I’ve heard) so I stick with 0-20
    Flash1034 and Paul631 like this.
  16. Feb 20, 2019 at 8:53 PM
    TRVLR500
    Wyoming
    Now that you mention it. I "do" have a 2004 and with VVT in these newer enginesoil selection is very important. I'd still run the thickest oil I could get away with though but it depends on where you live.
  17. Feb 23, 2019 at 6:44 PM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    The engine, VVT, oil pump/pressure etc is designed for the oil viscosity on the cap/in the manual, there's many fleet-use 4-cly out there with many abusive fleet miles to prove it.
