0w20 to 10w30 oil 2019 V6 auto
Discussion in '3rd Gen. Tacomas (2016-2023)' started by amocat91, Apr 29, 2025.
  1. Apr 29, 2025 at 4:11 PM
    amocat91
    amocat91 [OP] Member
    2019 sr excab v6 auto
    Truck runs great gets better gas mileage than my old 1995 4cyl Tacoma but the valve train noise always irritated me. Just drained and filled with Quaker State synthetic 10W30 and valve train noise is a whisper compared to before. I'm old school less noise is good. Anyone else done similar? Think my milage will take much of a hit? Anything I'm missing or failed to consider? Thanks for any input.
  2. Apr 29, 2025 at 4:22 PM
    Bishop84
    Bishop84 Well-Known Member
    Its unlikely it changed anything, once warm the oil flows the same unless exposed to extremes.
    The problem with 10W30 is winter starts, you'll have higher oil pressure than its designed to use.
    I'd suggest 0W30 or 5W30, 10W30 is basically obsolete, theres no reason to buy it, it just sits thicker on cold starts when you want thinner oil.
  3. Apr 29, 2025 at 4:24 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I’ve had nothing but 10w-30, 0w-40, and 10w-40 in mine since I bought it at 4K miles. At 72K now and all is well.
    Rusty66 and amocat91[OP] like this.
  4. Apr 29, 2025 at 4:26 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    the sewing machine sound is the injector cleaning cycle.
    BlackTRD4Me likes this.
  5. Apr 29, 2025 at 4:40 PM
    BillyE
    BillyE Well-Known Member
    You can use up to 15w-40 if you’d like. Whatever you use—your engine will almost certainly outlast every other component on the truck. Don’t overthink it.
    Toy_Runner and amocat91[OP] like this.
  6. Apr 29, 2025 at 4:41 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    BillyE likes this.
  7. Apr 29, 2025 at 4:42 PM
    amocat91
    Interesting, so the thick oil reduces that sound?
  8. Apr 29, 2025 at 4:44 PM
    545 Well-Known Member
    2015 Access Cab
    No
  9. Apr 29, 2025 at 4:46 PM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    Its your momo...do as you please. Honestly i just tell people mine is a diesel and they comply
    Rusty66 likes this.
  10. Apr 29, 2025 at 4:46 PM
    amocat91
    Winter here seldom gets below freezing. I did consider that though. I'll try 5W30 in the fall see if it stays quiet. Thanks
  11. Apr 29, 2025 at 4:49 PM
    amocat91
    That's my thinking also thanks.
  12. Apr 29, 2025 at 4:50 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Why not just stick to the recommended 0W-20?
  13. Apr 29, 2025 at 4:59 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    I always use 0W-30 and have used 0W-40 in summer.
    Once that oil is at temp, the engine sounds no different than with 20 weight in it.
    Chew likes this.
  14. Apr 29, 2025 at 5:05 PM
    InThePlains
    InThePlains Well-Known Member
    GM just told new 6.2 owners to put 0W-40 in theirs.
  15. Apr 29, 2025 at 5:20 PM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    But GM truck engines are ticking time bombs. You will end up with lifters in the engine.
  16. Apr 29, 2025 at 6:00 PM
    Koolbreeze7
    Jon
    Jersey
    no, but that was a big complaint concerning noise with this motor, wasnt sure if you knew to recognize that particular sound.
  17. Apr 29, 2025 at 6:03 PM
    MGMDesertTaco
    That's a shame. GM used to build reliable v8's that were cheap to upgrade and a lot of fun.
  18. Apr 29, 2025 at 6:04 PM
    InThePlains
    Toyota used to build reliable V8, too.
  19. Apr 29, 2025 at 6:07 PM
    MGMDesertTaco
    They sure did. Would have been a fantastic option for 4th gen Tacoma's and 6th gen 4Runners.
    STEELeR43 likes this.
  20. Apr 29, 2025 at 7:14 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    The only reasonable explanation I have heard discussed here for sticking to the 0w20 is that the vvt system needs the low viscosity to prevent rattle on cold starts until oil pressure builds.
    The factory manual has a table with various oil viscosities that are suitable to use up to 15w40 depending on temperature and driving conditions. Lots of stop/start traffic and towing would be considered hard use, especially in areas with high temperatures in the summer, indicating a much heavier than 0w20 oil to be used.
    I've used 5w30 since my first oil change at about 900 miles. If I were towing or offroading with any relative frequency, I'd run 15w40 during that time period and switch back to 5w30 in the winter.
    0w20 is to maximize fuel economy only in light duty use.
    BUZZCUT likes this.
